New Turntable w/pics!
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited September 2008
    http://www.tnt-audio.com/jpeg/schon_step3.jpg
    Pretty good example of where to start.
    You appear to be in luck regarding ease of VTA adjustment:
    "The 2 Xperience is equipped with the same 9" carbon fiber tonearm used in Pro-Ject's top-of-the-line RPM 9. It features a tapered conical arm tube to reduce standing wave reflections, a fixed aluminum head shell with high-grade copper wiring, hardened stainless steel bearings in sapphire cushes, a silicone-damped arm lift and easy adjustment of needle azimuth and VTA."
    DC
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • doctorcilantro
    http://www.project-audio.com/inhalt/en/manual/manual_xperiencec.pdf
    Page 4 describes VTA adjustment for this particular tonearm.
    DC
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    SCompRacer Posts: 9,122
    dagame27 wrote: »
    I have not messed with the VTA at all (I wouldn't know where to start to be honest).
    Not every stylus is where it should be. Start with the arm/cartridge parallel to the record and adjust VTA up and down until you get the richest fullest sound. Note that some cartridge/stylus are more sensitive to this adjustment than others. If you get too aggressive with VTA, you can change your stylus overhang.
    I basically have two settings, thick and thin.
  • hearingimpared
    hearingimpared Posts: 21,136
    My way of telling whether I have the VTA/SRA set properly is that when I make the adjustmenst up or down (for VTA) or lighter or heavier for SRA the music literally sound like it snaps onto focus. It is unmistakable.
  • strider
    strider Posts: 2,568
    Refresh my memory, Joe. SRA is stylus rake angle, the angle of the stylus in relationship to horizontal?
    Wristwatch--->Crisco
  • hearingimpared
  • ben62670
    ben62670 Posts: 15,969
    I'm going back to digital:p
    Ben
    ben62670 wrote: »
    Me too!:p:rolleyes::D
  • hearingimpared
    cough ~~~ pu$$ys~~~~ cough
  • jchouston
    jchouston Posts: 122
    edited October 2008
  • dagame27
    dagame27 Posts: 599
    edited October 2008
    I've had a chance to sit down for some extended sessions and am happy to say it sounds fantastic, a definite improvement from my last table. I tried to mess w/ the VTA, but it seems to be where it should. The sound seemed crisper in its current position. I am listening to Alison Krauss "live". The imaging through the SDA's is unreal!
    ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
  • hearingimpared
    edited October 2008
    I just checked out the pictures again and I'm sporting wood.
