HD Video Projector verus HDTV ?
ajanzalone
ajanzalone Posts: 128
edited September 2008 in Electronics
I have been toying with the concept of setting up a Video Projector, verus going the HDTV flat screen route.
I looked at the InFocus LP820 Video Projector 3200
3200 lumins is a very bright projector and should be able to work well, even in a well lit room.
Had anyone gone this route?
I will give you the HDTV will have a clearer picture as far as HD quality.
But size does matters and this would be a less expensive way to achieve a 60" to 70" screen size, tho I have not yet work out the setup logistics yet.
I have considered installing a 2" chase pipe from the projector position to the TV FIOS box & Sound equipment area, to pull cables, etc.
I have seen some wall screen paint but I have no idea of its effectiveness? anyone know?
Has anyone gone this route?
I would love to hear from some people using this type of Video viewer?
Tony
Audio Research SP5 Preamp
Quad 405 Amp
Pioneer Elite DV-48AV -
Outlaw 950 preamp/processor
Polk Monitor 10's
Velodyne VRP 1200 Sub Woofer
Success is having what you want ... but Happiness is wanting what you have!
Post edited by ajanzalone on
