Question about USB
Motzart
Ok the real high end Yamaha has a USB port to plug in your thumb drive with tunes on it.
Why can't someone make a accessory to plug into any receiver to do this??
Shouldn't hafta spend $1500+ to get this feature IMHO.
EX: Yamaha RX-V2700
EX: Yamaha RX-V2700
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
Im not aware of any commercial units but it could be done rather cheaply and I think there would likely be a big market for such a device.I have one that will take USB and output on headphones.With a simple mod it could be hooked up to an AUX in on a preamp or reciever.Testing
Testing
Testing -
Yeah mine has a nice place to plug in a 1/4 stereo patch cord from my Palm TX under AUX. Works great!!
One of only a coupla models that have this feature.
Be nice to adapt a USB do dad like you hook into the computer to plug there to use a USB thumb drive.
Phones: Sennheiser HD280 Pro -
So why not plug in an external Hard Drive with 400 Gigs of music?*
I know my DVD player has a USB outlet, but it's only v1.1 USB, which is too slow to be much use.
*assuming you've got 400 gigs of music. -
Ahhh that might come into play when adapting!
Might need a processor inside unit to convert?
I never thought of that. :rolleyes:
I think that's exactly the reason no do-dad exists. I would think it would need a menu system or modification of the existing set-up menu. The price is coming down on receivers with USB input. I played around with the Pioneer 1018 (around $450) a few weeks ago and it has the USB jack and you can plug a USB hard drive into it also. Currently I'm using an external USB to Optical sound card (converter) on a laptop to send music from my PC library to my Outlaw Pre/Pro so there are a few gadgets out there - maybe just not the exact one you need.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
The replacement to the Marantz SA-8001 SACD/CDP has a USB input also. I'm curious if it's only for thumb driver or if it could be hooked up to a PC also."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ding ding! On the receivers with this built in, the receiver itself does the decoding of the MP3s or whatever music and plays them. If it's not built into the receiver, your doo-dad has to do this same decoding, which will require a processor of some sort, not to mention some interface so you can choose / skip songs (again, this is built into the receiver on models that have USB).If you will it, dude, it is no dream.
