Bad hum from my B&K AV5000 II amp.
andrew_mac
Is it normal for these amps to have a hum? Or do I have a Bad amp? Is there anything I can do to stop this hum besides send it in for repairs?
Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Surround - RtiA1's
Center - CsiA6
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Post edited by andrew_mac on
Hmm,.It might be a ground loop problemSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
^^^ What he said.
Is this amp new to you or did this problem just start? Do you have a cheater plug you can use for a test, the three prong to two prong adapter. If yes try using it on you amp's power cord and see if it helps. Do you have it on a good power conditioner, not just a surge protector?AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I don't have a cheater plug but I have tried different outlets and I do uses a good power conditioner. I guess I should pick up one of those cheater plugs. The amp is not new. I Bought it second hand and this is the first chance I've tried it out.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
It's a faint hum/hiss mainly coming from the tweeters it seems. It occurs on all channels.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
