Bad hum from my B&K AV5000 II amp.
andrew_mac
andrew_mac Posts: 95
edited September 2008 in Electronics
Is it normal for these amps to have a hum? Or do I have a Bad amp? Is there anything I can do to stop this hum besides send it in for repairs?
Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's
Post edited by andrew_mac on
  • fbm211
    fbm211 Posts: 1,488
    Hmm,.It might be a ground loop problem
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • MADGSF
    MADGSF Posts: 603
    ^^^ What he said.
    Is this amp new to you or did this problem just start? Do you have a cheater plug you can use for a test, the three prong to two prong adapter. If yes try using it on you amp's power cord and see if it helps. Do you have it on a good power conditioner, not just a surge protector?
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • andrew_mac
    I don't have a cheater plug but I have tried different outlets and I do uses a good power conditioner. I guess I should pick up one of those cheater plugs. The amp is not new. I Bought it second hand and this is the first chance I've tried it out.
    Front - RtiA5's
    Surround - RtiA1's
    Center - CsiA6
    B&K Ref 50 Pre
    Amp - B&K AV5000 II
    Ben's Silver IC's
  • andrew_mac
    It's a faint hum/hiss mainly coming from the tweeters it seems. It occurs on all channels.
    Front - RtiA5's
    Surround - RtiA1's
    Center - CsiA6
    B&K Ref 50 Pre
    Amp - B&K AV5000 II
    Ben's Silver IC's
