Measure once, cut twice....???
tugboat
tugboat Posts: 393
Okay, did a stupid thing. I measured for new speaker wire for my surrounds and forgot to do it twice. Somehow I left out 7' for one of the speakers height on the wall. So now I have one speaker wired and routed perfectly and the other is wired, but not routed properly (diagonal down the wall). Since these are surround speakers, would it be okay to get the 7' I need, strip 1/2" off the end of each wire, separate the strands a bit, braid the two ends together, solder them and then shrink tube them? I really don't want to go out and buy another 24' of wire, but will if I have to.
Also, has anyone successfully use an electrician's fish tape to pull wire under carpet? For my back surrounds, I have an 8' section that I can hide the wire (door way and alcove). I was thinking of puting a small slit in the carpet next to the baseboard at both ends of the run and using a fish tape (wire pull) to get the runs through. I figure if the end of the pull is smooth, it should slide between the carpet and padding. Since I rent I can't drill and run under the floor.
Oh, and I can't use the wire for the rear surrounds as it's a different gauge and I only have enough for them (36' each).
Thanks!
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Post edited by tugboat on
  • tcrossma
    tcrossma Posts: 1,301
    edited September 2008
    I did exactly what you are asking for one of my surrounds due to running out of cable, and it works fine for me. If I cared more about the "HT" aspect of my system I'd probably always wonder if it was degrading the performance, but as it stands it's working fine for me.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • tugboat
    tugboat Posts: 393
    tcrossma wrote: »
    The speakers were calibrated with a SPL meter. I guess I can splice the wire and use the meter to see if the right and left are still equal in level. Not the best way to check, but it should do the trick.
    Thanks!
  • just_visiting
    just_visiting Posts: 40
    When I made my cables I was was worried that this would happen.
    Display: Sony XBR3 46"
    Pre/Pro: Marantz AV7005
    Amplifiers: Anthem MCA20 / Anthem MCA30
    CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
    DVD: Denon 3930CI
    BD: Pioneer Elite 05FD
    Sat: Bell TV 9241HD
    Game: Sony PS3 60GB
    Media Streamer: WDTV Live Hub
    Power Console: Panamax 5300PM
    Speakers: Paradigm Reference Studio v.3
    Subwoofer: SVS 16-46PC+
    Preamp: Parasound P3
    Amplifier: BAT VK60 Tube
    Sacd: Sony 777ES
    Power Console: Ultralink PGX-500
    Speakers: Paradigm Reference Studio 20 v.5
  • snow
    snow Posts: 4,358
    sploosh wrote: »
    can't help you there buddy. :(
    go there and make my day :)
    bye sploosh
  • utpalbarman
    utpalbarman Posts: 1
    Hi,
    Max
    Used Cars
  • steveinaz
    steveinaz Posts: 19,545
    tugboat wrote: »
    I would use crimp sleeves instead to do the splice.
  • tugboat
    tugboat Posts: 393
    steveinaz wrote: »
    Well already did the solder thing. I used a 12ga piece and soldered it to the 14ga. It seems to be working well. The speakers are LS f/x surrounds and are for critical listening.
  • xeb
    xeb Posts: 31
    probably depends a lot on how well the carpet is fixed down. ambitious i'd say but maybe possible... can't really hurt to try! good luck
  • polktiger
    polktiger Posts: 556
    Hi,
    Max
    Used Cars
    If you go this route, I would use the ultraflat wire. Your idea will work, but your main problem will be getting a snug fit on the carpet after you are done. If you don't use the flat wire you will get a bump in your carpet as your carpet pad naturally compresses over time.
  • concealer404
    concealer404 Posts: 7,440
    Hi,
    Max
    Used Cars
    Dude..... what kind of cars are you selling?
