Measure once, cut twice....???
tugboat
Okay, did a stupid thing. I measured for new speaker wire for my surrounds and forgot to do it twice. Somehow I left out 7' for one of the speakers height on the wall. So now I have one speaker wired and routed perfectly and the other is wired, but not routed properly (diagonal down the wall). Since these are surround speakers, would it be okay to get the 7' I need, strip 1/2" off the end of each wire, separate the strands a bit, braid the two ends together, solder them and then shrink tube them? I really don't want to go out and buy another 24' of wire, but will if I have to.
Also, has anyone successfully use an electrician's fish tape to pull wire under carpet? For my back surrounds, I have an 8' section that I can hide the wire (door way and alcove). I was thinking of puting a small slit in the carpet next to the baseboard at both ends of the run and using a fish tape (wire pull) to get the runs through. I figure if the end of the pull is smooth, it should slide between the carpet and padding. Since I rent I can't drill and run under the floor.
Oh, and I can't use the wire for the rear surrounds as it's a different gauge and I only have enough for them (36' each).
Thanks!
Thanks!
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Post edited by tugboat on
I did exactly what you are asking for one of my surrounds due to running out of cable, and it works fine for me. If I cared more about the "HT" aspect of my system I'd probably always wonder if it was degrading the performance, but as it stands it's working fine for me.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
The speakers were calibrated with a SPL meter. I guess I can splice the wire and use the meter to see if the right and left are still equal in level. Not the best way to check, but it should do the trick.
Thanks!Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way -
When I made my cables I was was worried that this would happen.Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5 -
bye splooshcan't help you there buddy.
go there and make my day
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Hi,
Max
Used Cars -
I would use crimp sleeves instead to do the splice.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Well already did the solder thing. I used a 12ga piece and soldered it to the 14ga. It seems to be working well. The speakers are LS f/x surrounds and are for critical listening.Driver carries only 20 dollars in ammunition
utpalbarman wrote: »Also, has anyone successfully use an electrician's fish tape to pull wire under carpet? For my back surrounds, I have an 8' section that I can hide the wire (door way and alcove). I was thinking of puting a small slit in the carpet next to the baseboard at both ends of the run and using a fish tape (wire pull) to get the runs through.
probably depends a lot on how well the carpet is fixed down. ambitious i'd say but maybe possible... can't really hurt to try! good luck -
utpalbarman wrote: »Hi,
Max
Used Cars
If you go this route, I would use the ultraflat wire. Your idea will work, but your main problem will be getting a snug fit on the carpet after you are done. If you don't use the flat wire you will get a bump in your carpet as your carpet pad naturally compresses over time. -
Max
Used Cars
Dude..... what kind of cars are you selling?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
