wassup with 4ohms 2ohms
vfx
would my sub blow if i hook up the incorrect ohms?
Post edited by vfx on
Can you be more specific; type of setup, amp, etc.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I know its a weird question but, Have you ever built a sub out of a cardboard box???
RT1 -
nope. i was just curious. i just paid for my audio guys to do everything.
reeltrouble1 wrote: »I know its a weird question but, Have you ever built a sub out of a cardboard box???
RT1
10 points for that question!Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
Subs don't blow with speakers at 2 ohms, but amps can. Make sure your amp is rated for usage at low impedances. Few home amps can handle it, lots of car amps are built for it , and larger pro audio amps usually are to.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
RT1
Yes, That's what I started with, after all angles were figured out I simply covered the cardboard box with 4 layers of fiberglass.:cool:
As far as your 4-2 Ohm sub question goes, the only way you could hurt anything is if your amp is not capable of delivering a 2 Ohm signal.Thanks, Jeff...
