wassup with 4ohms 2ohms
vfx
vfx Posts: 34
would my sub blow if i hook up the incorrect ohms?
Post edited by vfx on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited September 2008
    Can you be more specific; type of setup, amp, etc.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I know its a weird question but, Have you ever built a sub out of a cardboard box???
    RT1
  • vfx
    vfx Posts: 34
    nope. i was just curious. i just paid for my audio guys to do everything.
  • Sansui
    Sansui Posts: 372
    RT1
    10 points for that question!
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Subs don't blow with speakers at 2 ohms, but amps can. Make sure your amp is rated for usage at low impedances. Few home amps can handle it, lots of car amps are built for it , and larger pro audio amps usually are to.
  • Jeff Beaird
    Jeff Beaird Posts: 217
    RT1
    Yes, That's what I started with, after all angles were figured out I simply covered the cardboard box with 4 layers of fiberglass.:cool:
    As far as your 4-2 Ohm sub question goes, the only way you could hurt anything is if your amp is not capable of delivering a 2 Ohm signal.
    Thanks, Jeff...
