amp: from bridged to unbridged
SlowcarIX
going from bridged to unbridged, keeping the same gain/sub, will the sound level decrease?
thx!
thx!
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Buttkicker
Post edited by SlowcarIX on
It has for me."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes/probably. It did with my gear.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
In theory the only difference should be the maximum power available so using a single channel (unbridged) it will reach its clipping point sooner .going from bridged to unbridged, keeping the same gain/sub, will the sound level decrease?
thx!Testing
Testing
Testing -
thx!
Slowcar, how do you like your D-Sonic 2500-7? How is the sound quality and the reliablilty? Does it run as cool as you expected an ICEpower amp to be?
Thanks.
skykeysSpeakers:
. 5.2 surround config:
. . . In-wall L & R Fronts and Center: Polk LC265i, LCi-RTS-C. In-ceiling L & R rears: Polk LC80i
. . . Floor Subs: Polk DSWPro 500, Paradigm PDR-10
. Zone B: very old pair of Polk M 5's
. In Storage but still favored: Paradigm Monitors
AVR:
. Yamaha RX-V863
Universal DVD:
. Oppo DV-980H
TV:
. Sony Bravia XBR LCD 40" 720P (2005 vintage)
. Comcast Cable, Motorola box -
It may vary by amp them. I find myself having to adjust the gain after playing with bridged and unbridged modes on my Mac MC-126.In theory the only difference should be the maximum power available so using a single channel (unbridged) it will reach its clipping point sooner ."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
The biggest difference is the load. Bridged usually means you're driving the channels harder(2 or 4 ohm versus 8 ohm), therefore, you often get free power at the expense of the amp heating more. -
Depends on the amp. Some adjust the gain down when you engage the mono switch; others just just set both inputs to the same channel and reverse the polarity on one -which will give you twice the voltage.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Yeah ,looks like your Mac doesn't change the relative gain differences between the bridged/unbridged setting.Some manufactures like Bryston (atleast in their ST and SST 2 channel models) do change the gain appropriately to match the two.It may vary by amp then. I find myself having to adjust the gain after playing with bridged and unbridged modes on my Mac MC-126.
This is nice if you are running a multi amp setup consisting of bridged and unbridged units as the gains will be matched.Testing
Testing
Testing -
Thanks.
skykeys
they are very neutral sounding amps...7 monoblocks in one chasis, any coloration pretty much comes from the speakers. I leave mine on 24/7 in the everwarm state with a 12V trigger. This is my 2nd d-sonic amp and no issues so far...shorted the outputs many times, no harm done.
i leave the cover off...the 1000ASP blocks run much warmer than the 500ASPs...to a point where they are too hot to touch after a movie at very loud levels with 4ohm speakers.
check them out!my 7.(1x4) HT setup
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
ok...i went from bridged to unbridged on the face 1200 sub amp and w/o changing the sub/gain, there was a very significant drop in output - the speakers were overpowering the sub and had to redo a calibration.my 7.(1x4) HT setup
Buttkicker
