amp: from bridged to unbridged
SlowcarIX
SlowcarIX Posts: 887
edited September 2008 in Electronics
going from bridged to unbridged, keeping the same gain/sub, will the sound level decrease?
thx!
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Face
    Face Posts: 14,340
    It has for me.
    treitz3 Posts: 20,275
    Yes/probably. It did with my gear.
  • Systems
    Systems Posts: 14,872
    SlowcarIX wrote: »
    thx!
    In theory the only difference should be the maximum power available so using a single channel (unbridged) it will reach its clipping point sooner .
    Testing
    Testing
    Testing
  • skykeys
    skykeys Posts: 102
    SlowcarIX wrote: »
    thx!
    Slowcar, how do you like your D-Sonic 2500-7? How is the sound quality and the reliablilty? Does it run as cool as you expected an ICEpower amp to be?
    Thanks.
    skykeys
    Speakers:
    . 5.2 surround config:
    . . . In-wall L & R Fronts and Center: Polk LC265i, LCi-RTS-C. In-ceiling L & R rears: Polk LC80i
    . . . Floor Subs: Polk DSWPro 500, Paradigm PDR-10
    . Zone B: very old pair of Polk M 5's
    . In Storage but still favored: Paradigm Monitors
    AVR:
    . Yamaha RX-V863
    Universal DVD:
    . Oppo DV-980H
    TV:
    . Sony Bravia XBR LCD 40" 720P (2005 vintage)
    . Comcast Cable, Motorola box
  • Face
    Face Posts: 14,340
    GV#27 wrote: »
    It may vary by amp them. I find myself having to adjust the gain after playing with bridged and unbridged modes on my Mac MC-126.
  • ShinAce
    ShinAce Posts: 1,194
    GV#27 wrote: »
    The biggest difference is the load. Bridged usually means you're driving the channels harder(2 or 4 ohm versus 8 ohm), therefore, you often get free power at the expense of the amp heating more.
  • unc2701
    unc2701 Posts: 3,587
    Depends on the amp. Some adjust the gain down when you engage the mono switch; others just just set both inputs to the same channel and reverse the polarity on one -which will give you twice the voltage.
    Backburner:Krell KAV-300i
  • Systems
    Face wrote: »
    It may vary by amp then. I find myself having to adjust the gain after playing with bridged and unbridged modes on my Mac MC-126.
    Yeah ,looks like your Mac doesn't change the relative gain differences between the bridged/unbridged setting.Some manufactures like Bryston (atleast in their ST and SST 2 channel models) do change the gain appropriately to match the two.
    This is nice if you are running a multi amp setup consisting of bridged and unbridged units as the gains will be matched.
    Testing
    Testing
    Testing
  • SlowcarIX
    skykeys wrote: »
    Thanks.
    skykeys
    they are very neutral sounding amps...7 monoblocks in one chasis, any coloration pretty much comes from the speakers. I leave mine on 24/7 in the everwarm state with a 12V trigger. This is my 2nd d-sonic amp and no issues so far...shorted the outputs many times, no harm done.
    i leave the cover off...the 1000ASP blocks run much warmer than the 500ASPs...to a point where they are too hot to touch after a movie at very loud levels with 4ohm speakers.
    check them out!
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    ok...i went from bridged to unbridged on the face 1200 sub amp and w/o changing the sub/gain, there was a very significant drop in output - the speakers were overpowering the sub and had to redo a calibration.
    my 7.(1x4) HT setup
    Buttkicker
