Soni caps vs....
ben62670
Well Dayton's have been the cheapo leaders I will never suggest them over Sonicaps for highs again. If budget is a constraint They are much better than stock. For highs if you are doing an upgrade the sonicaps are worth the money. They are the closest to an active XO so far that I have seen. Anything in the signal path has some sort of an effect. The sonicaps have the least sonic impact of all compared to full active XO's so far as I can tell.
Ben
Ben
Ben
Ben
Post edited by ben62670 on
you mean that you strayed away from them? I am totally devastated that you would do such a thing :eek:
Good night ,Ben
JC approves....he told me so. (F-1 nut) -
I used Sonic Craft caps for the high end for my SRSII's and could not be more happy.
By the way I love the following
Originally Posted by TroyD
CL35 has no idea what he's talking about, pay him no attention. He wouldn't know good sound if it crawled up his leg and bit him on the ball bag.
BDT -
I've used Dayton and Sonic Caps for the highs and lows in a few different speakers.
I agree, Sonic Caps are the better capacitor for most applications. The only time I would recommend Dayton instead of Sonic Caps is if you needed a forward sounding cap. Solen are even more forward, but are shrill up top and can make vocals sound nasal."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
