How to use CATV jacks for digital coax audio
ben62670
ben62670 Posts: 15,969
edited September 2008 in Basic Hookup/Wiring Questions
Well my computer is in one room, my main stereo in another, and my ghetto stereo in another, Well I wanted the ability to hook up my puter to my DAC, and receiver. Fortunately I have my puter in the basement, and the cables are all wide open down here. I figured out which cable goes to which jack, and made an adapter from CATV to RCA. Hooked it up, and bingo digital broadcast;) I don't know how many jacks you could broadcast over, or how far you could run it. Digital cable/sat uses much higher bandwidth than audio so I see no problems with this.
Ben
Ben
Post edited by ben62670 on
  • Eric W
    Eric W Posts: 556
    edited August 2008
    Sounds good. When I throw parties- to hook up all my sound systems together, I've used an old Minidisc player to be the A to D converter from my DJ system. Then used cheap scrap coax cable, ran it out the window of one side of the house, up over the roof and back down into another window to feed one of the coax ins on the preamp of another sound system. Using RCA to F type adaptors on both ends. Works perfect! :D
    -Eric
    -Polk Audio
  • ben62670
    edited August 2008
    Eric Wong wrote: »
    ....Then used cheap scrap coax cable, ran it out the window of one side of the house, up over the roof and back down into another window to feed one of the coax ins on the preamp of another sound system. .....
    Thanks for the early morning smile:)
    Truth be told thats how it looks in my basement now. I have not gone the finished route yet. I was conducting a test of "the emergency digital audio broadcast system":D
    Ben
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    That's interesting-I'll have to try that with my PC to my HT rig.
    ____________________
    Pool: Atrium 60's/45's
  • Serendipity
    Serendipity Posts: 6,975
    This has worked in the past for me too.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
