Closed / noise reducing headphones
AndyGwis
Anyone know of a good pair for under $100?
Must be new, must be closed and/or noise canceling design, must be under $100, strong preference to over the ear as opposed to in-ear / buds.
Thanks! Saw a couple pairs on Amazon but wasn't sure what others would suggest.
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
Post edited by AndyGwis on
I have these. Definitely old school style but I really like them. I even use them with my iPods. Very Comfortable.
Sennheiser HD280 Pro.
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004974
You can find them just about anywhere for > $100."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I've also used HD 280 Pros for a long time (2+ years ... maybe more?) for music listening and PC gaming, and have been very happy with them. I think the bass slam has perhaps weakened over the years, but other than that they should as good as they did when I got 'em. Very solid cans for probably around $75.
p.s. Shack I think you meant < instead of >.
My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
