Closed / noise reducing headphones
AndyGwis
AndyGwis Posts: 3,655
edited August 2008 in Electronics
Anyone know of a good pair for under $100?
Must be new, must be closed and/or noise canceling design, must be under $100, strong preference to over the ear as opposed to in-ear / buds.
Thanks! Saw a couple pairs on Amazon but wasn't sure what others would suggest.
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
Post edited by AndyGwis on
  • shack
    shack Posts: 11,154
    edited August 2008
    I have these. Definitely old school style but I really like them. I even use them with my iPods. Very Comfortable.
    Sennheiser HD280 Pro.
    http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004974
    You can find them just about anywhere for > $100.
  • jwhitakr
    jwhitakr Posts: 568
    edited August 2008
    I've also used HD 280 Pros for a long time (2+ years ... maybe more?) for music listening and PC gaming, and have been very happy with them. I think the bass slam has perhaps weakened over the years, but other than that they should as good as they did when I got 'em. Very solid cans for probably around $75.
    p.s. Shack I think you meant < instead of >. ;)
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
