ATTN ThinkPad Users - Need Help ASAP
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2008
    I have a feeling it's a supervisor password that was already in the laptop but didn't get activated until you enabled security.
    On my laptop, I have a "Supervisor Password," "Power-on Password," and a "User Password." I noticed that you can set one of the passwords and still get into windows, but once you try to enter the BIOS it prompts for the Supervisor Password.
    Maybe this is what is going on - the previous owner set one of the passwords but it didn't come up until you started tinkering with it?
    I'm not 100% sure though...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2008
    Sounds logical to me.
    ____________________
    Pool: Atrium 60's/45's
  • Serendipity
    edited August 2008
    mmadden28 wrote: »
    Thanks. I have my laptop in front of me right now, and I found out that you can accidentally set the "Supervisor Password" and forget about it because it doesn't prompt for it ever...until you go into the BIOS and try to change the "User Password".
  • Serendipity
    edited August 2008
    Crap - I just did this to my own laptop. But I knew the password.
    What happened was I set a "Supervisor Password" and was still able to get into Windows fine. I restarted twice and had no problem getting into my computer. Next, I tried to set a "User Password" and it prompted for my "Supervisor Password." I tried what you did and put in the WRONG password just to see what happens.
    Surprise - after 3 wrong tries it locks up the system. Now you can't do ANYTHING with it unless you have the "Supervisor Password."
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    There is no way a local guy is going to be able to crack a bios password. You will probably WILL have to send it in.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • mmadden28
    edited August 2008
    Not true. there are ways to do it, you just have to have the right tools. It this is related to the security modulke that is in the Thinkpads, there is likely know workaround, but a BIOS password? There may be ways-Can you boot to a CD or USB?? I'll see if I can find my 'workaround tools'
  • Serendipity
    edited August 2008
    So - is audiobliss' issue the same thing as what my little 'experiment' uncovered? And if it is indeed a bios password, is there an easier way to reset it?
  • Serendipity
    edited August 2008
    audiobliss wrote: »
    Here's my line of thinking...if there was already a supervisor password in there, it wasn't asking for that because the security was off. However, when I set up a user password in windows, registered my fingerprints, and turned on the security, it then could have put that old password into place.
    I think this may be the problem. If I set a supervisor password on my laptop, it won't ask for it because the supervisor password isn't needed to get into the OS. However, when I want to set a user password, I have to enter the supervisor password (which I set previously) and entering the wrong password (ex: admin, password, etc.) causes the laptop to display "System Halted."
    Is this what's going on? And are there any other details?
    billbillw Posts: 7,564
    edited August 2008
    Dude, I think you are fu<(ed!
    IBM/Lenovo do things differently and pretty much leave you screwed if you don't have that supervisor password.
    http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=migr-59377
    At this point, I'd make the guy refund/exchange for another one if he cannot provide you a way to unlock it.
  • Serendipity
    edited August 2008
    That's what I was thinking. If I understand correctly after reading the IBM support site, not having the supervisor password prevents you from doing anything. I guess you'll either have to get a refund on the laptop or have IBM clear the password for you.
  • Serendipity
    edited August 2008
    Audiobliss,
    Did you ever get this figured out?
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2008
    Ok, folks. I apologize for the HUGE delay in my response time, here. This was (and still is) a huge issue for me, but I headed out to college Wednesday and have been moving into the dorm and getting settled in since then. But now that I have classes staring me in the face for Monday and really really wanna be able to take notes on this laptop, this is priority numero uno tambien.
    First off, I thank every one in this thread very much for their input and effort in trying to find some kind of a solution with this, even if it's only sharing previous experiences with similar problems.
    However, I do have more information on what's going on now. Turns out this isn't my fault or the seller's fault, but rather Lenovo's own oversight. When I set up the password originally through Lenovo's Windows-based program, I used a letters and symbols. The program took them all just fine and I'm assuming set those, somehow, as a password. But the problem is that trying to enter the password before Windows starts up, it can't read the symbols.
    So, basically, the Windows set-up program let me enter something for the password that the computer can't read during the stage at which it asks for the password. I stayed on the phone for an hour with a programming friend who has access to all kinds of information, including Lenovo's scripted tech service info. We tried several things, including entering the Unicode for the symbols via alt+****. However, that didn't work. :(
    Now I'm seriously considering doing something like this, even though I don't know how to solder, 'cause I NEED this thing working:
    http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Serendipity
    edited August 2008
    Do you need help with soldering? If so, I can give you some pointers - send me a PM :)
  • mmadden28
    edited August 2008
    Personally I would avoid soldering on the mainboard. I would try to find a way to hold a couple leads on while somebody else did the PC actions. But if you decide to solder watch your soldering iron temp and how long you heat the area-You don't want to cook the chip or surrounding chips.
  • Serendipity
    edited August 2008
    mmadden28 wrote: »
    As long as you're careful, it is possible to solder on the mainboard and then remove it later. At least from my previous experiences when fixing my Onkyo AVR, JVC SVHS, etc.
  • mmadden28
    edited August 2008
    appadv wrote: »
    Yep-its possible-as you said with steady hands-- and even better with a heat sink.....It just seems, according to the article that the data connection only needs to be made for a few seconds for the 'read', so if you can hold some leads (connected to the DB9) steady, you might avoid any soldering at all. When not working with a heat sink, and soldering around discrete compnents (ICs), you run a higher risk of causing failure.
  • audiobliss
    edited August 2008
    Thanks for that idea, guys. If I decide I need to go that route, I'd be much more comfortable with trying to hold the leads in place rather than soldering them.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited August 2008
    Solder the wires, you could have been done with this project 2 days ago.
  • audiobliss
    edited August 2008
    First off, I want to give a big thanks to Fireman32 for giving me a call on a lazy Sunday afternoon to help me in this predicament. Turns out there's not much to do to it since I'm locked out of the BIOS, but I wanted to say thanks for the concern and effort!
    Well, it sure SEEMS like that's a solid way of retrieving the password. And perhaps that will be fruitful. However, the issue is that the password I have to enter includes characters that it won't accept as input. So it's totally possible that'll just end up giving me what I already know the password is, but I still won't be able to enter it. I'm just hoping that the system somehow changed the password or interpreted those symbols into something else that it will let me enter. Hopefully I'll get around to finding that out today.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2008
    I hope that when you solder the wires you find out the password (and it's one that you can type in)...
  • audiobliss
    edited August 2008
    Thanks, man, me too! Only bad thing is...in this small town...Radio Shack was closed today. :(
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2008
    audiobliss wrote: »
    How about Home Depot? Walmart? Or your local hardware store?
