recommend a good Sub to go with my Lsi9s.
kkennally
kkennally Posts: 13
edited September 2008 in 2 Channel Audio
Please help recommend a good Sub to go with my Lsi9s.
I am looking for a quality sub to be used with a 2 channel music only system.
I have a small to medium sized room and a budget from $400-700 for the Sub.
My system consists of:
Cambridge Audio Azur 740A integrated amp
Cambridge Audio Azur 640C V2 CD player
2 Lsi9s on epos 35st stands sitting on top of 3” granite plinths
Looking at Polk pro, Velodyne, Martin Logan dynamo
Thanks,
Kevin
Music room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Living room:Onkyo Amp ,Onkyo DX-C390, Polk Audio RTi6's, Polk Audio PSW505
Post edited by kkennally on
  • dkg999
    dkg999 Posts: 5,647
    edited August 2008
    I would go listen to the Polk DSW micro-pro line of subs.
    DKG999
  • mantis
    mantis Posts: 17,557
    edited August 2008
    The Micros are nice but the Martin Logan dynamo is much quicker and more musical. Go listen for yourself.
    Dan
    Dan
  • kkennally
    kkennally Posts: 13
    edited August 2008
    Would the PSW1000 (Lsi) Sub be worth waiting for and spending the extra money for? Would they go better with the Lsi9s?
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    What is your budget, room size, and intended application? (2 channel or home theater).
    Also any WAF issues with a really large sub or are there certain dimentions you would not be comfortable going over? (I.E. cant be taller than x or bigger around than y for example.)
    How are your DIY skills? Would you even be interested in trying to build one or would you rather purchase a pre-built unit?
    Standard answers are SVS, HSU, Epik, eD, Outlaw (HSU design), etc. Just though I might try and taylor something that fits your needs a little better than the standard replys... :)
    Welcome to Club Polk.
    Michael
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited August 2008
    Welcome to the club,I'm in the same boat,looking for a small sub to compliment our 2-channel rig.
    I've decided on a Velo SPL-1000R...just waiting to get the funds together.
    The ML Dynamo might be more in your price range,but there are several good subs on A'gon
  • kkennally
    kkennally Posts: 13
    edited August 2008
    Well, it looks like I am going with the Martin Logan. The local tweeter has them for $599.00
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    Congrats - from what I hear, you will like the Martin Logan.
    Michael
  • curved
    curved Posts: 664
    edited August 2008
    As I said in my other post that you posted:
    curved wrote: »
    Personally I would wait a little longer until you can afford a little more especially with your current setup. You have such a nice setup!!!
    I listened to a ton of subs and felt that I needed to spend a little more for my needs....and boy I'm glad I did. My sub is so tight, clean and the perfect addition for my setup.
    http://www.snellacoustics.com/ProductDetails/3472.asp
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • lakesailor
    lakesailor Posts: 319
    edited August 2008
    It looks like you have already committed; however I would have strongly suggested SVS. A friend just got one and it is amazing. Completely blows away my Paradigm Servo 15 reference sub.
  • kkennally
    kkennally Posts: 13
    edited August 2008
    Thanks for the help.
    System with the Martin Logan installed.
    K.
    2798458900_9217bccc15.jpg?v=0
  • Doc99
    Doc99 Posts: 100
    Nice system! Just curious how you have your sub connected?
  • leroyjr1
    leroyjr1 Posts: 8,785
    How does it sound?
