recommend a good Sub to go with my Lsi9s.
kkennally
Please help recommend a good Sub to go with my Lsi9s.
I am looking for a quality sub to be used with a 2 channel music only system.
I have a small to medium sized room and a budget from $400-700 for the Sub.
My system consists of:
Cambridge Audio Azur 740A integrated amp
Cambridge Audio Azur 640C V2 CD player
2 Lsi9s on epos 35st stands sitting on top of 3 granite plinths
Looking at Polk pro, Velodyne, Martin Logan dynamo
Thanks,
Kevin
Thanks,
Kevin
Music room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Living room:Onkyo Amp ,Onkyo DX-C390, Polk Audio RTi6's, Polk Audio PSW505
Post edited by kkennally on
I would go listen to the Polk DSW micro-pro line of subs.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
The Micros are nice but the Martin Logan dynamo is much quicker and more musical. Go listen for yourself.
DanDan
Would the PSW1000 (Lsi) Sub be worth waiting for and spending the extra money for? Would they go better with the Lsi9s?Music room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Living room:Onkyo Amp ,Onkyo DX-C390, Polk Audio RTi6's, Polk Audio PSW505 -
What is your budget, room size, and intended application? (2 channel or home theater).
Also any WAF issues with a really large sub or are there certain dimentions you would not be comfortable going over? (I.E. cant be taller than x or bigger around than y for example.)
How are your DIY skills? Would you even be interested in trying to build one or would you rather purchase a pre-built unit?
Standard answers are SVS, HSU, Epik, eD, Outlaw (HSU design), etc. Just though I might try and taylor something that fits your needs a little better than the standard replys...
Welcome to Club Polk.
Welcome to the club,I'm in the same boat,looking for a small sub to compliment our 2-channel rig.
I've decided on a Velo SPL-1000R...just waiting to get the funds together.
The ML Dynamo might be more in your price range,but there are several good subs on A'gon -
Well, it looks like I am going with the Martin Logan. The local tweeter has them for $599.00
ThanksMusic room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Congrats - from what I hear, you will like the Martin Logan.
As I said in my other post that you posted:Personally I would wait a little longer until you can afford a little more especially with your current setup. You have such a nice setup!!!
I listened to a ton of subs and felt that I needed to spend a little more for my needs....and boy I'm glad I did. My sub is so tight, clean and the perfect addition for my setup.
http://www.snellacoustics.com/ProductDetails/3472.aspLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
It looks like you have already committed; however I would have strongly suggested SVS. A friend just got one and it is amazing. Completely blows away my Paradigm Servo 15 reference sub.
Thanks for the help.
System with the Martin Logan installed.
K.
Nice system! Just curious how you have your sub connected?
How does it sound?
