New HSU subs.. on the way!
lanion
In case you didn't know, Hsu just let their new sub out of the bag last night.
Sealed, 15" Sub, 1000 watts, WIRELESS connectivity (wow!), major discounts for buying more than one at at time.
http://forum.hsuresearch.com/showthread.php?p=32382
My Iron Man training/charity blog.
HT:
32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
HT:
Post edited by lanion on
hmmm...uls-15 quaddrive
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Lanion --
I see you ordered two of 'em. Very nice. Please share your thoughts and lots of pics once they arrive.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
will it run stereo or will you stack them up?my 7.(1x4) HT setup
Buttkicker
Very nice !
Not sure I would want a wireless sub thoughCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Very nice !
Think about the 1 big downfall of a sub. The place in your room for best bass may be impossible to get wires to run to and look nice. I think this is an awesome addition and cannot wait until it trickles into the mainstream. Just think of the possibilities. Wireless rears with SDA technology built in. (along with the wireless interconnect cable for them) A complete wireless SRT system would just be awesome.
I am glad a real speaker company finally came out with something. I just can't wait to see what is on the horizon.
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable -
Michael
But wouldn`t you loose something, or possibly add something (noise) into the sound ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I think it is OK for sub to use wireless as it only needs to transfer low frequency signal. But not recommended to use wireless technology on full range speaker. The loss will be a lot higher.
HT:
32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900. -
Very nice!
So do you have a matching pair in the back of the room too?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
in my 12' x 12' x 8' room sadly not. Freq response from the mains is actually pretty awful against the wall where the couch has to be, so I calibrated for 'edge of your seat' listening to be perfect. I think if I pull the couch 2 feet forward my wife won't understand
HT:
Well, you've got em pretty flat...how do they sound?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Its better than any setup I have heard... I'm very happy! They are cleaner or as clean as my other speakers, and they can keep up SPL wise with my 300 watt Outlaw 7900. I'm happy!
For disclosure, that is limited to movie theaters, my old LFM-1 EX/MBM setup and showrooms with KEF equipment.My Iron Man training/charity blog.
HT:
Mine arrived this week. I held out for the Espresso finish. Probably not the most popular finish to go with, but looks nice with LSi9's in ebony.
I'll try to get some pics up... digital camera is giving me a "memory card error" right now. -
no ground prong in the IEC. I guess they are tired of ground loop issues. Works for me. I think they could have put in a ground lift switch like Bryston for that money. Of course they are probably buying their amps from somebody, not making them. Speaking of that what's with the only power rating being "RMS short term"? RMS tests per FTC are supposed to be for an hour aren't they? And 1K watts at what load? 2? 4? 8 ohms? Even the downloadable .pdf manual says only that same "spec". It would be nice to see a real RMS from X-Y HZ @ Z ohms w/ Q% distortion type spec. I sold HSU a few years back. It's good stuff, they should tell buyers the whole story. Did you see that if you want to run 4 you need 4800 watts AC - that's a minimum of two dedicated 20A outlets. I think four might rattle an old house apart!
ET
System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant! -
Lanion, what center are you using?
http://www.paradigm.com/en/reference/centers-studio-series-2-3-13.paradigm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I noticed that you're using Polk LSI fronts. How do they match up, as far as transition goes?
