CL2-3 Speaker Wire suggestions
xandra
I've been perfectly satisfied with Monoprices Oxygen free speaker wire...
but I bought some 14g CL2 stuff from them recently, but upon striping the wire looked more like 16g or even 18g...
so now I'm looking for some decent (NOT pricey) CL2 or CL3 14g speaker wire. (max run about 50ft).
Anyone?
Anyone?
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
What about monoprice's 12g CL2 stuff. I have used it before and thought the gauge was plenty thick enough. Plus, the price can't be beat.
I was going to add a link to the last post since monoprice.com was down this morning, but that option isn't available anymore...
So here it is:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2816&seq=1&format=2 -
http://www.partsexpress.com/webpage.cfm?webpage_id=3&CAT_ID=56&ObjectGroup_ID=376
The Carol stuff is decent. They have 14 gauge in 2 or 4 conductor, in 100 foot rolls or by the foot.-Eric
-Polk Audio -
Anyone?
I'm sure it's 14ga, unless they sent you the wrong item. CL2 speaker wire has much thinner jackets inside the outside casing than regular speaker wire.
I have been using this wire, it's very high quality, CL3, and definitely 14ga:
http://www.accessories4less.com/make-a-store/item/SQSCL1425WH/SOUNDQUEST/14AWG-2-Conductor-In-wall-Speaker-Wire-White-100ft/1.html -
Thanks all - Based on the numerous comments: sounds like I just got a mis-marked coil (s#!*happens)
thanks allLR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
