How to bi-amp Monitor 70s?
BjornB17
BjornB17 Posts: 752
edited August 2008 in Speakers
I'm going to buy a Emotiva UPA-7 in the coming weeks and would like to be sure how i need to bi-amp them using a Harman Kardon AVR-340 as the pre-amp. I will be using 5 of the UPA-7 channels for the front 3 channels (2 channels to each Monitor 70 and a single one to the CS 2). Do i run a RCA y-splitter from the AVR-340 preout to 2 of the UPA-7 inputs for each speaker to be bi-amped? And then i just run speaker wire from 2 channels of the UPA-7 to each Monitor 70? Does it send the full range singnal to the speaker? What stops the tweeter from playing a full range signal, for example?
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    Yep - thats bout it. (don't forget to remove the jumper between the speaker terminals before you hook up the amp though)
    y-cable to 2 inputs on the amp. speaker cable from one output to the top terminals, another speaker cable from the other output to the bottom terminals.
    Your tweeter will not get a full range signal for the same reson it does not now. Inside the speaker the terminals go from the terminals, to the crossover to the speakers. The crossover is what protects your speakers from getting signals they were not designed to reproduce.
    Have fun,
    Michael
  • curved
    curved Posts: 664
    edited August 2008
    Exactly what McLoki said..... ;)
    I think you will be very impressed at how well those 70's sound with that amp. Very good choice!!
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
