A nice DIY project
awe-d-o-file
Here is a link to a very thorough DIY project copy of Walker Hi-definition links that attach in parallel to your speaker wire. It's a 36 page pdf so it takes a little time to load. The author did a nice job.
http://alanmaherdesigns.com/Documents/HRSCF_Project_rev-1.pdf
ET
System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
Post edited by awe-d-o-file on
thanks will try to download and go through to gain some knowledge
Nice! I'm thinking it may not help with tube amplifiers because they roll off the very high frequencies but I'd like to give it a try sometime. For quite awhile I've been thinking of trying ferites which should perform a similar function but I think this would do a better job.Vinyl, the final frontier...
If this is a project you are interested in, it has great step-by-step instructions and is pretty well written.
