MSB Link Dac wiring problem
joeparaski
For those of you familiar with MSB products, I have the Link Dac and the seperate P1000 Powerbase. I revised my setup in the rack and I need to place these 2 components side by side.
The problem is that the interconnect wire between the Powerbase and Dac (supplying electrical power to the Dac) is now too short. I called MSB and they want $95 to make a longer cable. This seems quite steep, does anyone have any ideas or solutions or know of a supplier that has a decent price for such a cable?
Right now I'm running the Powerbase upside down so the cable can reach the DAC.
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
Are the conectors molded on or removable?If removable you could get some cable(ie Beldon) with same number and guage of conductors and transfer your power connectors on to the new longer cable.Testing
Testing
Testing -
The cable ends are molded one piece round connectors with 6 pins.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
It might be possible to obtain another female and male connector of the same type and build an extender.If you post a pic of the connector type I will see if Electrosonic or Digi Key have soimthing.Testing
Testing
Testing -
Why isn't it just sitting under the dac?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
He is rearranging the rack. It sounds good but the OCD in him makes him mess with the rig. He HAS to do something to it.
ChuckTesting
Testing
Testing -
The photo of the upper half of the rack shows the 2 Sony carrousel cd players side by side, they used to be one over the other. But since I got a 3rd player (a Pioneer), I decided to put the units side be side (the Pioneer is on the far right).
The MSB units are directly below the Sony players, where aesthetically, it makes more sense. But the Powerbase is upside down because of the connector.
As for the connector, if anyone knows where to get one at a reasonable price, I need one. I'll go check out the local electronics store today.
I believe what you need 6 pin DIN connectors. http://www.active-tech.ca/b2c/redirect.cfm?pn=2&lang=eng&CFID=41409538&CFTOKEN=28316812&jsessionid=203076709fb95c617448TR&locationID=itemDetail_3&itemID=25%2D260%2D0 Note.the pic in the link is actually of a 5 pin not six pin.Testing
Testing
Testing -
I guess the picture is not too clear....but it IS a 6-pin I have. Thanks for the link.
Yeah, it is the pic in the link that is wrong,for some reason the pic shows a 5 pin instead of a 6 pin as the writing says.joeparaski wrote: »...but it IS a 6-pin I have.Testing
Testing
Testing -
joeparaski wrote: »I guess the picture is not too clear....but it IS a 6-pin I have. Thanks for the link.
Joe
Reread your post...got it, pic is 5-pin but listed as 6-pin.
