Audio Coaxial/Video Coaxial difference?
joeparaski
Is there a difference between these 2 cables? Can a cable labeled "Video Coaxial" be used for Audio Coaxial and vice-versa?
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
As far as I know there is no differences other than marketing purposes. There should be no difference between the same branded cables listed as either audio or video in there makeup.
engtazengtaz
engtaz
+1
I've used a composite video cable as a coax audio cable and a coax audio cable as a video cable before. So aside from marketing purposes, they should both do the trick.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Video coax is 75 ohms, the same as digital cable. Interconnects are usually around 50 ohms. As stated, they will work for either application though, but I wouldn't use a regular interconnect as a digital cable."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the info guys, much appreciated.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Some systems actually give you a regular mono interconnect as a digital coax cable. Case in point: The Onkyo HTiB's come with a mono IC and tell you to connect that between coax on the DVDP and AVR.polkaudio RT35 Bookshelves
Yes, and it's probably 75ohms. My Marantz CDP came with one too. I don't know where you're going with that.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I was going to say, that cable works as a video cable, coax audio cable, or as a mono IC. It's the same cable as the included RCA cable in the box, only that the RCA is two molded together.
If it works for all the above, then I would assume it's okay to use it for multiple purposes.polkaudio RT35 Bookshelves
