Audio Coaxial/Video Coaxial difference?
joeparaski
joeparaski Posts: 1,865
edited August 2008 in Electronics
Is there a difference between these 2 cables? Can a cable labeled "Video Coaxial" be used for Audio Coaxial and vice-versa?
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • engtaz
    engtaz Posts: 7,675
    edited August 2008
    As far as I know there is no differences other than marketing purposes. There should be no difference between the same branded cables listed as either audio or video in there makeup.
    engtaz
    engtaz
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2008
    engtaz wrote: »
    engtaz
    +1
    I've used a composite video cable as a coax audio cable and a coax audio cable as a video cable before. So aside from marketing purposes, they should both do the trick.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Face
    Face Posts: 14,340
    edited August 2008
    Video coax is 75 ohms, the same as digital cable. Interconnects are usually around 50 ohms. As stated, they will work for either application though, but I wouldn't use a regular interconnect as a digital cable.
  • joeparaski
    edited August 2008
    Thanks for the info guys, much appreciated.
    Joe
  • Serendipity
    edited August 2008
    Face wrote: »
    Some systems actually give you a regular mono interconnect as a digital coax cable. Case in point: The Onkyo HTiB's come with a mono IC and tell you to connect that between coax on the DVDP and AVR.
  • Face
    Face Posts: 14,340
    edited August 2008
    Yes, and it's probably 75ohms. My Marantz CDP came with one too. I don't know where you're going with that. :confused:
  • Serendipity
    edited August 2008
    Face wrote: »
    I was going to say, that cable works as a video cable, coax audio cable, or as a mono IC. It's the same cable as the included RCA cable in the box, only that the RCA is two molded together.
    If it works for all the above, then I would assume it's okay to use it for multiple purposes.
