Ps3
brittle
Does the PS3 upconvert standard dvd's? I've heard both yes and no from different sources. Also, can someone who owns one tell me any reason not to buy one? I will be running it thru a Pioneer VSX94TXH to a Samsung HL67A750 t.v. via HDMI. Thanks in advance.
Brittle
Pioneer VSX 94TXH AVR
Polk LSi-15 front
Polk LSi-15 rear
Polk PSW1000 sub
Polk LSiC center
Samsung HL67A750 DLP
Sony PS3
Polk LSi-15 front
Polk LSi-15 rear
Polk PSW1000 sub
Polk LSiC center
Sony PS3
Post edited by brittle on
I would have to think it would upconvert. I'm pretty sure the one I had did.
Nick -
It not only upconverts dvds but also things like ps2 games (40GB isn't backwards compatible) and non-hd segments of blu-rays via the latest firmware.
Only reason not to get one is if you need analog outs for compatibility with older equipment (not a problem if you can use hdmi along the whole chain). If you don't want to bother with third party solutions to having IR universal remote compatibility as the ps3 uses bluetooth for its remote and controllers. Or you need to bitstream trueHD or DTS-MA to your receiver for decoding instead of having the ps3 internally decode them.
Otherwise you get a high quality blu-ray player and game machine that meets or exceeds features of most dedicated blu-ray players currently available. There are some just released and soon to be released blu-ray players from panasonic, sony etc. that finally match the ps3 feature for feature and add the analog outs and lossless audio bitstreaming features so they can do it all. But you might have to wait for dedicated players like these to be competitive with the ps3 price point. -
i got one and i like it a lot, i would say get onereciever-Yamaha rxv1700
front-RM50t
center-RM30
surrounds-M40
rear surrounds-RM30
velodyne minivee
playstation 3 -
It is the best upconverter I have seen. Better than my Oppo 981hd or my Pioneer Elite. Outstanding value for the money.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Ditto.
I also own a Ps3 and choose it over every single Blu ray player. I work in the field so I get to see all kinds of Player go on different displays including 170 inch Screens. I have found no other player to better the ps3. I only hate that it doesn't have the ability to be controlled with a control system. You have to use it's own controller or remote. It's ok but I perfer just using on control for the entire system. There is a 3rd party Ir system but you can't turn it on. That still sucks. So I put no stock into it. Until someone releases(it should be sony) a Ir or Rs232 or even IP control, then the Ps3 will be completely superior to all other players. But at it's price point and all it can do, it still holds that title even without control. Most people will not find that to be a problem. It's not for me Personally. I just use the game controller and I'm ok with that. You don't have to waste your money buying there Blue tooth remote. It's not nessary.
The Pioneer Elite 94 is one sweet receiver. It's my personal favorite under 1600.00. It's fantastic.
DanDan
I'd say get one. The only reason from my experience not to get one is if your ambient room temperate is 'warm' the PS3 fan can sometimes be very annoying. It's not a deal breaker, but make sure your ps3 has good air flow and a nice cool room to operate in.
It upscales through HDMI not component I believe
Also its NOT that good of an upscale player. No way its better then the oppo players or my HD DVD XA1. Does a decent job but not great.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
I did a side by side comparison of Oppo vs. PS3 on upscaling and the PS3 won. And if you include divX or .avi it wins hands down. As for the XA1 I've never seen one playing but read they are one of the best at upscaling. It needs to be said though that the differences in the Oppo picture and the PS3 are minor. Both are superb.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
I am going to agree with Fongolio here. With the latest firmware updates, the PS3 is one of the best upscaling players out there short of anything with a Realta chip or outboard processing. I recently did a shootout between 4 players: PS3, Toshibe HD-XA2, Pioneer DV-59avi, and Oppo 981. All 4 are considered really exemplary upscalers and in some cases, it was too close to call a winner (like when using suberbit SD transfers). But on poor to mediocre quality video, the PS3 and XA2 were essentially indistinguishable. I was really surprised as I thought that the Reon in the XA2 would win for sure. The Pioneer wasn't far behind, followed by the Oppo. All have different processing types (PS3 - graphics card, XA2 - Reon VX, Pioneer - proprietary, Oppo - Faroudja DCDi) so that can obviously account for some of it, but it's really tough to beat the PS3 upscaling for under $1500 and basically impossible for under $500. Just get one.
This weekend I decided to upgrade the TV and bought a Sammy HL56A650 from best buy. The offered me a $100 off a blue ray player, so I bought the Sony Bdp-S300 because it has the 5.1 analog outs. The sound quality was great, the rest of it sucked. Loads time was 3 minutes at best, menus to forever to load. I returned it the next day for a PS3 and I couldn't be happier. Loads much faster, can network it, will update itself (I tried for over an hour to load the latest firmware on the 300), with the bluetooth remote I can run an HDMI cable to the bedroom TV and control it. Best of all, it gives me an excuse to upgrade the receiver!Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
Load time on the PS3 is the best thing about it. Turns on immediately, loads very quickly.
It's a great piece of equipment. I'm very impressed by it, and I'm pretty much only using it for rare movie watching and a few games here and there.
Once I figure out media server and other features, it will be that much better. If you have an HDMI receiver, it's a no brainer! Too bad my lil receiver doesn't do HDMI. Oh well, I think I'll hang onto it anyway.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
The PS3 is NOT in the same class as the XA2 for upscaling. Its not even close.
PS3 and Oppo are close but Oppo beats it out but not by much.
Dont get me wrong the PS3 is good but not great. And not even close to the XA2. The XA2 is flat out amazing.
This is based off my testing/findings.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
I could easily see how that could happen. I didn't test on 1080p displays, only 720p. I know the XA2 would win on a 1080p setup. It also depends on what display you're using. The Oppo did admirably on my LCD but was the worst by far on the DLP projector. But like I said, the XA2 only does a better than the rest when using poorer quality transfers. Take it for what it's worth. But it sounds like we have an ex-HD-DVD fanboy...
Just playin, I liked HD-DVD too. -
I've aso considered the fact that I possibly have a defective Oppo because I was highly disappointed by it. I thought compared to the Pioneer DV-59avi it would be an improvement, but found that that wasn't the case. The Oppo sounded anemic on SACD and DVD-A and the video wasn't any better than the similiarly priced Pioneer. I read all the hype and was either expecting too much, or just got a defective unit.
I own XA1, XA2, PS3, Xbox 360 and Wii over 80 movies on HD DVD and over 100 on Blu Ray I enjoy movies and HD.
But I did do a lot of test for upscales DVD's I have over 1000 so I kinda wanted the best upscale player. And I found the XA2 wins hands down.
IMHO.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
IMHO.
To stay on topic, if you have HDMI capable receiver, definitely get PS3 for BluRay - it's a true Profile 2.0 (upgradable) player. You will get your hi-def sound and picture through HDMI.
For upconversion of standard DVDs, not many consumer players (if any) can beat Reon HQV chipset. Reon HQV is used in Toshiba HD-XA2 and Samsung BD-P1200 (and in upcoming 2400). Having XA2, I know for the fact that XA2 will outperform other players including XA2 in upconversion. (I will check out BD-P1200 as soon as I'll get it next week).Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
The XA2 will out perform the XA2 in upconversion?? do you mean the PS3?(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
Denon AVR-891
Harmoney One Remote
While the Reon chip is a great upscaler, it is expensive. When the xa2 was released, it retailed for $999 IIRC. There are a number of receivers from Onkyo that have this chip if you really want it, but they also retail north of 1000 bucks. You can probably get used xa2s on ebay for a few hundred bucks. But you're basically limited to hd-dvds already released and whatever quality you're lucky to get off of ebay.
The ps3 is a quality player that Sony sells at a loss because of the razor/razor blade profit model of the gaming industry. Reon quality is great, but I wouldn't expect any player to eek out the last bit of picture quality possible with chips like the reon and have the feature set of the console at the budget price the ps3 goes for. I have a reon in my onkyo pre, but I really prefer to just let the ps3 handle all the upscaling just because the pre sometimes has trouble figuring things out when it gets the wrong signal fed to it. The ps3 is happy to convert everything from games to dvds without any problems, and I've never missed the quality since I don't watch movies with an A/B switch...;) -
Thanks to all for the input, very helpful. My friend won the PS3 in a contest and wants 200 bucks for it, he says its the 60GB version. Is it worth buying the remote? I will be using it mainly for watching movies.Brittle
Polk LSi-15 front
Polk LSi-15 rear
Polk PSW1000 sub
Polk LSiC center
Sony PS3 -
You're lucky, the 60GB is the best version sony made. It has all the ps2 hardware included for the best backwards compatibility and it has the media card slots, wireless networking etc.
If you will be using it as a media hub, you might want to drop in a new hard drive before you load up the current one. It accepts generic laptop SATA hard drives (easy instructions are in the manual). So if downloadable content might be your thing, you can do it now or wait until later. But 250GB drives are under a hundred bucks. And even a 320GB goes for the occasional $99 sale.
As far as the controller goes, you can do everything with the game controller. It just depends on how comfortable you are using the controller as your remote. If you just have to have your fast forward and pause mapped to traditional buttons, get the remote. Otherwise, it's pretty easy to use the controller. I recently bought the remote, but I used the controller so much already that I'm still getting used to the remote buttons again. -
Yes, sorry, I mean XA2 over PS3.While the Reon chip is a great upscaler, it is expensive. When the xa2 was released, it retailed for $999 IIRC. There are a number of receivers from Onkyo that have this chip if you really want it, but they also retail north of 1000 bucks. You can probably get used xa2s on ebay for a few hundred bucks. But you're basically limited to hd-dvds already released and whatever quality you're lucky to get off of ebay.
As I said, BD-P1200 Blu-Ray player has a Reon XQV in it. 2400 will have it too. 1200 does not break the bank in any way or form.
Regarding PS3, nice catch on a 60GB!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
It's been a while since I've looked at this player. Did they ever get the glitches fixed by a firmware update?
http://www.highdefdigest.com/tags/show/Technical_Glitches
Also, it's still far short of the full feature set in the ps3. But you are right that it's affordable, especially at closeout for the new models. -
I just ordered my Onkyo 806 from crutchfield ($999). Can't wait to fire up my HT for the first time. Now I know how some ppl feel when they talk about the anticipation of getting new gear.
I wonder if PS3 sound quality is the same as Bluray player? My guess is not but I may be wrong.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
suprafantx wrote: »I wonder if PS3 sound quality is the same as Bluray player? My guess is not but I may be wrong.
The PS3 outputs a digital signal. Most of the work is done by the DAC's in the receiver. For HT, I think the transport will have little to do with sound quality.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Sound quality is stellar and many options are supported that aren't necessarily supported on a dedicated player. You have support for all the new high resolution formats that are only now gaining full support on the latest blu-ray players. Including TrueHD and DTS-HD MA. The ps3 lacks the ability to bitstream the formats to a receiver for decoding in the receiver. But the audio from the internally decoded PCM (same format the receiver ends up with after receiver decoding) is great. Just make sure everything is configured correctly on the receiver side so it can recognize and process the decoded signal properly (DAC and digital surround processing still depends on the quality of the receiver).
CDs sound great especially over hdmi. And except for the 40GB, you can even play SACDs. A rare option on blu-ray players.
What many people who "guess" at the abilities of the ps3 fail to take into account is that video games require far more processing, graphics, and network power than playing a simple blu-ray. This leads them to the conclusion that a game console could not possibly beat a dedicated player in features or quality. However, modern game consoles are more like desktop computers than the older game machines. I think you can even run linux. And the best thing is that because of the razor/razor blade model of the gaming industry, all this hardware is sold at a loss so they can eventually make money on the game software.
So you end up with a console that has a far better general processor, installed memory, graphics chip, and networking capabilities than is available in a dedicated player which has to be profitable based on its initial sale. And the console was designed from the start with 1080p video and multi-channel surround sound all via hdmi. This is why, the ps3, available basically at blu-ray's launch several years ago, continues to add features to compete head-to-head with the latest blu-ray players just releasing now.
The only things the ps3 can't do are hardware related. It doesn't have the proper hdmi 1.3 chip to do bitstreaming. And it doesn't have a reon chip for upscaling. But other than that, people who bought a blu-ray launch ps3 have only seen their investment grow as they would have otherwise had to upgrade if they bought a launch dedicated player. Among the many firmware ps3 enhancements:
Upscaling both legacy dvds and games to full 1080p
Internal decoding of DTS-HD MA
24fps native movie cadence output for blu-rays
Increased upsampling options of audio sources
More options for video output controls including RGB/NTSC black (for computer monitors vs. TVs)
Blu-ray Bonus View compatibility (Profile 1.1)
Blu-ray BD-Live compatibility (Profile 2.0)
And the ps3 still prompts users for easy firmware updates every month or so when you connect to the network. So they're constantly improving the platform's features and stability which are already very good. -
Man, I'm glad I didn't wait. I got the PS3 60GB version and have kept the firmware updated. It does a superb job with SDs and BRs, and with PS2 games. IMO, it's a no-brainer for someone wanting to get into BluRay for a reasonable price.
If you can get the 60 GB for $200, you best jump all over it before he wakes up and realizes what he's got. If you don't want it, I'm sure someone here would gladly take it off your hands for like $250."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I hijacked a thread earlier and thought I should start a new one...
I know and understand that you can swap out the internal HD of the PS3 for bigger. Can you also load MP3's or other song formats on an external HD and connect to the PS3?
Also, will the PS3 rip songs from a CD onto the HD?
Or...I currently have a PC set up as a media PC, but the way I have it setup is somewhat inconvenient. Is there a way that the PS3 can see the PC over my network and play songs of the PC harddrive?
Edit... Damn it... I mean to start a new thread. Sorry...HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Can I get 1080i with component cable?
