Where to find a SDA cable?
TurboJim
I contacted customer service and apparently my connector has been discontinued. My speakers have I guess the "pin-blade" type of connector. The plug appears to have a 1/8" headphone jack and below it a small rectangle slot with it looks like 2 contacts in it. Does anyone have this cable in a 20' length to sell? Or maybe a pinout where I can go to radio shack and MAKE one?
__________________
Jim Testa
jtesta1966@aol.com
Maint HT:
Mitsu 55511 HDTV, SDA-SRS 2.3, CS350, RT2000, Denon AVR3806, DBX 3bx/120x, Denon DVD-2900, Sony SA222ES, Carver M1.5t, Monster 3600, SA8300 Cable box/DVR
Bedroom system
Sharp AQUOS 32" LCD, Onkyo TSXR800, Bost Acoustimass 15, Pioneer DVD, Pioneer DVD-R
Jim Testa
jtesta1966@aol.com
Maint HT:
Bedroom system
Post edited by TurboJim on
You will get replies soon Jim.
Har_Navalta/F1Nut are excellent sources for that information. Har actually makes those cables if I recall.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Jim,
Here's a link to one that Har made. You could do it yourself, if so inclined.
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=7260&highlight=interconnect+cable
Welcome to the forum and if I may, you've got to get some better power for those high current hungry 2.3's.
F1Political Correctness'.........defined
President of Club Polk -
Thanks for the welcome. Glad to be here
Looks easy enough. Buy a 20' RCA pair, Grind the shield off an RCA plug, throw some heat shrink on it, and a spade on the second wire. Thats it?????__________________
Jim Testa
jtesta1966@aol.com
Maint HT:
Bedroom system
Sharp AQUOS 32" LCD, Onkyo TSXR800, Bost Acoustimass 15, Pioneer DVD, Pioneer DVD-R -
I believe so, but let Har give it his blessing.Political Correctness'.........defined
BTW: What receiver would YOU recommend? Home theater is a MUST.... and I dont have loads to spend.... $1000 tops__________________
Jim Testa
jtesta1966@aol.com
Maint HT:
Bedroom system
I'm not the right guy to answer that question as I'm a 2 channel only guy. Try doing a search for receivers or someone who has a better idea will chime in sometime soon. Buying used (Audiogon) is a great way to get better gear for less money. One thing you need is to be sure it's a high current model.Political Correctness'.........defined
Jim,
Post your AVR rec question over in "Electronics".More later,
Tour...
Vox Copuli
