Where to find a SDA cable?
TurboJim
TurboJim Posts: 8
edited May 2003 in Flea Market
I contacted customer service and apparently my connector has been discontinued. My speakers have I guess the "pin-blade" type of connector. The plug appears to have a 1/8" headphone jack and below it a small rectangle slot with it looks like 2 contacts in it. Does anyone have this cable in a 20' length to sell? Or maybe a pinout where I can go to radio shack and MAKE one?
__________________
Jim Testa
jtesta1966@aol.com
Maint HT:
Mitsu 55511 HDTV, SDA-SRS 2.3, CS350, RT2000, Denon AVR3806, DBX 3bx/120x, Denon DVD-2900, Sony SA222ES, Carver M1.5t, Monster 3600, SA8300 Cable box/DVR
Bedroom system
Sharp AQUOS 32" LCD, Onkyo TSXR800, Bost Acoustimass 15, Pioneer DVD, Pioneer DVD-R
Post edited by TurboJim on
  • dorokusai
    dorokusai Posts: 25,637
    edited May 2003
    You will get replies soon Jim.
    Har_Navalta/F1Nut are excellent sources for that information. Har actually makes those cables if I recall.
    F1nut Posts: 52,264
    edited May 2003
    Jim,
    Here's a link to one that Har made. You could do it yourself, if so inclined.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=7260&highlight=interconnect+cable
    Welcome to the forum and if I may, you've got to get some better power for those high current hungry 2.3's.
    F1
  • TurboJim
    TurboJim Posts: 8
    edited May 2003
    Thanks for the welcome. Glad to be here :)
    Looks easy enough. Buy a 20' RCA pair, Grind the shield off an RCA plug, throw some heat shrink on it, and a spade on the second wire. Thats it?????
    __________________
    Jim Testa
    jtesta1966@aol.com
    Maint HT:
    Bedroom system
    F1nut Posts: 52,264
    edited May 2003
    I believe so, but let Har give it his blessing.
  • TurboJim
    TurboJim Posts: 8
    edited May 2003
    BTW: What receiver would YOU recommend? Home theater is a MUST.... and I dont have loads to spend.... $1000 tops
    __________________
    Jim Testa
    jtesta1966@aol.com
    Maint HT:
    Bedroom system
    F1nut Posts: 52,264
    edited May 2003
    I'm not the right guy to answer that question as I'm a 2 channel only guy. Try doing a search for receivers or someone who has a better idea will chime in sometime soon. Buying used (Audiogon) is a great way to get better gear for less money. One thing you need is to be sure it's a high current model.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2003
    Jim,
    Post your AVR rec question over in "Electronics".
    More later,
    Tour...
    Vox Copuli
