DWS Pro 400 (Carpet)
dei08dei
While looking at the Pro 400 at Fry's, the salesman tells me that the 400 is a bottom firing sub. He said that since it is a bottom fiiring sub, it should NOT sit on carpet. A piece of wood or plexi-glass should be placed over the carpet. Is this true or have I been had??????
Post edited by dei08dei on
Carpet damps highs, not bass sound waves that are 20 foot long.......HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote: »Carpet damps highs, not bass sound waves that are 20 foot long.......
I am dense. I don't understand "not bass sound waves that are 20 foot long". -
You'll be fine as long as the woofer itself isn't hitting the carpet."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Bass wave lengths can approach 20 feet in length, and can penetrate nearly anything. That is why you hear cars thumping from blocks away. You never hear the highs, even if they are played just as loud, as they are absorbed/stopped by solid objects in their paths.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote: »Bass wave lengths can approach 20 feet in length, and can penetrate nearly anything. That is why you hear cars thumping from blocks away. You never hear the highs, even if they are played just as loud, as they are absorbed/stopped by solid objects in their paths.
Thanks. -
I have mine on carpet. You can also configure the DSW series for forward firing if you feel so inclined, or if it will help you sleep better at night.
Cheers,
Cheers,
Russ
Thanks Russ. I did not know I could reconfigure it. I will try it to hear the difference.
