Preferred Analog Interconnect...
PS Audio Statement
MAS Silver -
Um mine!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Already got you, see first page...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Ben -
Dammit you bunch of cable whores, give me advice! I'm looking at Audioquest's entry level stuff... should I get G-Snake or Sidewinder cables to connect my amp to my preamp? I've got some tweeter hiss and I hope a better cable can cut down on it.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Audio Technica AT-LP120
Mirage CMD-5 x 5
Bic H-100 -
If you have tweeter hiss, I don't believe the issue resides within your interconnects.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Yeah, I just cleaned/reseated everything and the hiss is back down to almost inaudible more than 6" from the speaker. That was a close one.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
I have not tried alot - (copperheads, Blue Jeans, Signal and BW Audio (bens' braided silver specials).
The BW Audio is what has won out from what I have tried and is finding a growing presence in all my analog spots.
MIT's are where its at.
I have not tried a lot either but the Audioquest Copperheads were the best so far.
White Zombie Zero Point ZeroTNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
RutgersFTW wrote: »Dammit you bunch of cable whores, give me advice! I'm looking at Audioquest's entry level stuff... should I get G-Snake or Sidewinder cables to connect my amp to my preamp? I've got some tweeter hiss and I hope a better cable can cut down on it.
I found no audible difference between Sidewinder and Copperhead, so go Sidewinder. Both of these interconnects are very nice, but handle them carefully. I broke the connection on 2 different occasions with Copperhead.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
nikolas812 wrote: »I have not tried a lot either but the Audioquest Copperheads were the best so far.
Copperhead/Sidewinder are both very good IC's. Very nice treble presentation.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
RutgersFTW wrote: »I've got some tweeter hiss and I hope a better cable can cut down on it.
Tweeter hiss is probably due to a noisey source. Cables won't do anything for this. Are you only hearing this with the volume maxed and no program material? If so, it's normal to hear some hiss up close to the tweeter--this is the noise floor.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Exactly. I think my NAD is more powerful/revealing than my H/K, so some sources (particularly the cable box) have a very high level of noise while others (OPPO) have almost none.
That said, is there anyway to mitigate and decrease the noise floor without swapping electronics?Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
You can reduce it sometimes by using good cable management behind your rack. Make sure all AC/digital/IC's are seperated as much as possible.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Mapleshades Excalibur ribbon unbalanced. 1 meter.2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Updated...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I just redid most of my connections with appropriate length Monoprice Premium cables to declutter/separate AC from signal. Though they were a little on the pricey side, I think the tight-fitting connectors are worth it. They're my new favorites.
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
Good advice. This is the most important thing to do. Also be sure to cross IC's at a 90 degree angle. If they run parallel with any other cables they can pick up noise;)
Ben -
White Zombie Zero Point Zero.TNRabbit
Sunfire TG-IV
New IC of choice...Bogdan Silver Spirit. Just tried em...and wow. Impossible to find used though.
Yep, I just did this with measured lengths and separate cable channels for AC and ICs, with my power amp on the bottom and speaker cables ran on their own. My noise floor is down down down and I'm very happy.You can reduce it sometimes by using good cable management behind your rack. Make sure all AC/digital/IC's are seperated as much as possible.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Mirage CMD-5 x 5
Bic H-100 -
Tie wraps and tie-wrap stand-offs do the trick. I have all cables seperated and my system is DEAD quiet. I even set my equipment on the rack based on where connections will fall. My video components are all run via toslink, so they don't interfere with 2-channel audio.
Go here: http://members.cox.net/stepheninaz/audio_connection_scheme.xlsSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Only drawback to the Copperheads and Sidewinders, and the lower end AQ brand cables is the frequency of RCA molded plug failure. When it comes to cables, the lower end AQs fails more than most. Sonically they do a great job when functioning.[ -
Yep, they have to be handled very carefully, the solid conductor won't take alot of stress. I have broken 2 of them in the past.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Do not be confused there is now and there has always been only the one, to whom all others aspire.
Thou shalt not want after MIT, enjoy the ride.
RT1 -
reeltrouble1 wrote: »Do not be confused there is now and there has always been only the one, to whom all others aspire.
RT1
MIT, pffffttttt. You better be an MIT grad if you want to afford those things...:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
well not exactly the same thing but was accepted into IIT back in my engineering days.......
like many here steve I scower the used market looking for deals on MIT and buy demo and trades, the Shotgun line works for me, I have to give credit to Doro for getting me started on the MIT jonesin trail. I like this wire for the added bass I hear and it makes the treble more refined, not really rolled off just more refined and fun to listen to. I know everyone has there favorite and I support any wire someone feels fits there system.
Of course if you not using MIT your just confused.
RT1--effers ought to pay me endorsement fee's. -
I also haven't looked anywhere else after trying MIT Interconnects."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
