Check out the sliding shelf
Early B.
Early B. Posts: 7,900
edited July 2008 in Electronics
Getting to the back of your gear to change cables can be a hassle. So I found a simple solution -- a tray that slides out. Check it out...
"God grooves with tubes."
002.JPG 389.2K
001.JPG 370.4K
Post edited by Early B. on
  • Early B.
    edited July 2008
    Lasareath wrote: »
    I would guess that tray is very strong? and screwed in well?
    It's one of these: http://www.amazon.com/gp/product/B0002BG41Q
    It has a 50 lb. weight capacity, but I have about 85 lbs. on it. It's screwed into the wood very securely, so it ain't going anywhere. The shelf actually slides out 14 inches, but I'm only gonna slide it out half way.
    Warning: If you're timid, on blood pressure medicine, or rarely like to try new things, don't attempt this stunt at home. :p
  • avguytx
    avguytx Posts: 1,628
    edited July 2008
    Hmm...Is it me or do those wall AC outlet adapters look a little scary?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited July 2008
    EarlyB: You can't fool everybody on this forum. I see exactly what you are doing here. Sure the shelf will last a few weeks . . . maybe even months, but sooner or later it's gonna fail and your equipment will be damaged. And then! And then! You will have your reason to buy something new all while never appearing to Flip Flop on your previous statements. . .
    Early B. wrote: »
    Well, I'll probably upgrade the HT pre/pro later this year to get the new HD capabilities, but that purchase really doesn't count. If I stick with Emotiva, I'll get 40% off, so it's a no brainer. But yeah, for 2-channel I'm done. Believe it or not, I'm getting bored with upgrading.
  • Face
    Face Posts: 14,340
    edited July 2008
    You're out of your mind.
  • george daniel
    george daniel Posts: 12,096
    edited July 2008
    SolidSqual wrote: »
    Oh yeah,, it's coming,,like an elephant walking down the street,,, it's coming :);)
  • okiepolkie
    okiepolkie Posts: 2,258
    edited July 2008
    I've used this one in several installations:
    http://www.middleatlantic.com/enclosure/roll/reb.htm
    It hold a little more weight, and I do like the swiveling feature.
    The one you linked to at Amazon is actually a shelf meant to be installed in a rack, so it wouldn't have the screw down capabilities that the REB19 has. The REB is a little more expensive, but they do work as advertised.
    Tschüss
    Zach
  • Early B.
    edited July 2008
    okiepolkie wrote: »
    I like it. The swivel feature is very nice. However, at $186, it's almost double the cost of the one I got, and the REB has no ball bearing slides or a latch to keep it closed, and the shelf is 1/2 inch particle board.
    I drilled four holes in the bottom plate so I could hold the unit down with screws. The steel is a heavy 16-gauge, so since the shelf is rock solid and not installed in a rack designed for computer gear, it should be able to hold a lot more weight.
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2008
    avguytx wrote: »
    My thoughts exactly............I was going to ask the same thing. I would be afraid of that thing melting with the current draw of all that gear.
  • Early B.
    edited July 2008
    Sherardp wrote: »
    Don't worry. There's a surge protector behind all of those wires. Besides, there isn't very much current flowing through the gear. The amp on that outlet is only powering a pair of rear speakers and center channel.
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2008
    avguytx wrote: »
    It looks like one of the pictures the Fire Department uses as what not to do with elctrical outlets. I guess next we will see a bathtub installation. :)
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2008
    Does that outlet have it's own breaker? :D
