Check out the sliding shelf
Early B.
Getting to the back of your gear to change cables can be a hassle. So I found a simple solution -- a tray that slides out. Check it out...
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I would guess that tray is very strong? and screwed in well?
It's one of these: http://www.amazon.com/gp/product/B0002BG41Q
It has a 50 lb. weight capacity, but I have about 85 lbs. on it. It's screwed into the wood very securely, so it ain't going anywhere. The shelf actually slides out 14 inches, but I'm only gonna slide it out half way.
Warning: If you're timid, on blood pressure medicine, or rarely like to try new things, don't attempt this stunt at home.
"God grooves with tubes." -
Hmm...Is it me or do those wall AC outlet adapters look a little scary?Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
EarlyB: You can't fool everybody on this forum. I see exactly what you are doing here. Sure the shelf will last a few weeks . . . maybe even months, but sooner or later it's gonna fail and your equipment will be damaged. And then! And then! You will have your reason to buy something new all while never appearing to Flip Flop on your previous statements. . .Well, I'll probably upgrade the HT pre/pro later this year to get the new HD capabilities, but that purchase really doesn't count. If I stick with Emotiva, I'll get 40% off, so it's a no brainer. But yeah, for 2-channel I'm done. Believe it or not, I'm getting bored with upgrading.
You're out of your mind."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
SolidSqual wrote: »EarlyB: You can't fool everybody on this forum. I see exactly what you are doing here. Sure the shelf will last a few weeks . . . maybe even months, but sooner or later it's gonna fail and your equipment will be damaged. And then! And then! You will have your reason to buy something new all while never appearing to Flip Flop on your previous statements. . .
Oh yeah,, it's coming,,like an elephant walking down the street,,, it's coming
JC approves....he told me so. (F-1 nut) -
I've used this one in several installations:
http://www.middleatlantic.com/enclosure/roll/reb.htm
It hold a little more weight, and I do like the swiveling feature.
The one you linked to at Amazon is actually a shelf meant to be installed in a rack, so it wouldn't have the screw down capabilities that the REB19 has. The REB is a little more expensive, but they do work as advertised.Tschüss
Zach -
okiepolkie wrote: »I've used this one in several installations:
I like it. The swivel feature is very nice. However, at $186, it's almost double the cost of the one I got, and the REB has no ball bearing slides or a latch to keep it closed, and the shelf is 1/2 inch particle board.
I drilled four holes in the bottom plate so I could hold the unit down with screws. The steel is a heavy 16-gauge, so since the shelf is rock solid and not installed in a rack designed for computer gear, it should be able to hold a lot more weight.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
My thoughts exactly............I was going to ask the same thing. I would be afraid of that thing melting with the current draw of all that gear.Shoot the jumper.....................BALLIN.............!!!!!
Don't worry. There's a surge protector behind all of those wires. Besides, there isn't very much current flowing through the gear. The amp on that outlet is only powering a pair of rear speakers and center channel.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
It looks like one of the pictures the Fire Department uses as what not to do with elctrical outlets. I guess next we will see a bathtub installation.
Three 20 amp circuits. -
Does that outlet have it's own breaker?
