Pioneer VSX-92TXH Questions
obieone
obieone Posts: 5,077
edited July 2008 in Electronics
This is for the owners, if any, here.
Question 1: Does this rcvr. have tone control? i.e. bass/treble?
Question 2: IF yes, is it on the remote?
I'm looking to buy one, and I don't have the ability to 'play' w/ one at the store locally. And the product sheet doesn't give that info.
Thanks.
Post edited by obieone on
  • Frank840
    Frank840 Posts: 262
    edited July 2008
    yes the reciever have tone/ treble,bass, ect. there is not a button on the remote for just treble or bass. depending on the setting you are using 2 channel for example you hit set up after hitting Direct or Stereo and select bass or treble but in HT. you have to hit setup ,go to x curver for treble and bass curve to ajust how low you want the bass to go or high ect.
    Frank
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • mantis
    mantis Posts: 17,561
    edited July 2008
    obieone wrote: »
    Thanks.
    The receiver has a Automatic Mcacc calibration which you don't have to Bass and trebble it.. Thats old school but as said it can be done.
    The 92 is a good receiver. I perfer it over most.
    Dan
    Dan
  • obieone
    edited July 2008
    Thanks guys. That nailed the purchase for me. Not 'critical' that it's on the remote, but I just wanted to make sure I could adjust the bass if need be.
    I just have to go get it.
  • Fongolio
    Fongolio Posts: 3,516
    edited July 2008
    It's more like a graphic equalizer and yes it can be set manually with the remote and a gui on the tv or on the face of the unit.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
