Oh crap!!
I made the mistake of looking at my Lsi25's today. The front speaker cover on one was showing plastic on the right side, about an inch long where the cloth had pulled away from the frame. It's also starting to pull away in a different spot. I know that is nothing major, but it's like finding a tear on your new sofa, Just kills the mood abit. Anyone else have this issue, or am I the only lucky ducky?? The other speaker cover is perfect. Looks like a call to customer service is my next step.
Post edited by Fatwalnut on
I have an LSi15 whose speaker "cloth" has come partially unglued at the top, in the center. It is still attached at both top edges so it has not unraveled. If possible, when you check with support can you find out what a new cover costs? Thanks.
Interestingly, I also have a pair of SDA2s that I bought in the late 80s. Within a few years the side panels on both speakers came detached. You can see that they were simply glued on with one meandering, like a snake, trail of glue on each side.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
BlueFox,
I will contact customer service on Monday July 28. Once I have an answer for you, I will post it here. Thanks for responding.
