My DIY phono pre
    treitz3 Posts: 20,137
    edited July 2008
    Dibs on being the Beta tester!
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    perfect timing
    Smoke test in 5 4 3 2 1...
    Ben
    edited July 2008
    Well?
  • ben62670
    edited July 2008
    no smoke power good
    Ben
  • ben62670
    edited July 2008
    Well I should have picked a different album to play. Another one bites the dust was not a good choice. The PS was dead on, but when testing the op-amp was putting out a full 15vdc:confused: The power is on the other side of the board. Everything tests out good on the board. The only thing it could be is a bad op-amp. This one was pulled from I don't remember what. The new op-amps won't be here till Monday. I was really looking forward to getting my ear on this, but there is no way I could hook this up yet. All my other op-amps here are all dual package. I am very frustrated. The local rat shack has nothing!
    Ben
  • ben62670
    edited July 2008
    Op amp was shot. I tested it alone, and it was internally shorted. Thats good, and bad. The new ones will be here soon. I ahve only had about 6hrs sleep in the last 3 days. I am going to take a break, and listen to tunes:)
    Ben
    Ben
  • ben62670
    edited July 2008
    I need a solution.
    What I am looking for is an 8 pole relay(line level). Any suggestions?
    Ben
