Is this alright
bigaudiofanatic
bigaudiofanatic Posts: 4,415
Okay I want to Bi-amp my monitor 40's I just want to take a break from surround for a while. My question is this. My yamaha rx-v361 has front and rears speaker outputs. Can I set the receiver to 5 channel stereo and connect the rear wires to the back of the monitor 40's and have the front wires connected to the back of them as usual. Or will this not work.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • Eric W
    Eric W Posts: 556
    edited July 2008
    Should work fine, though it also depends on if the Yamaha does any processing to the signal in 5-ch stereo mode. Just make sure you remove the jumper from the back of the speakers. You can also use the level calibration controls to adjust the relative tweeter/midbass levels. You probably want to go into the setup menu, set both front and rear speakers to "large."
    -Eric
    -Polk Audio
  • bigaudiofanatic
    edited July 2008
    Good deal than I am going to do it now. I'll let you know how it sounds be back in a bit.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited July 2008
    The clarity has improved quite a bit and the bass seems to be more deep. NICE I dont think I want to go.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Eric W
    Eric W Posts: 556
    edited July 2008
    Ahhh... someone discovered bi-amping. That's why we make it available on the vast majority of our speakers :)
    -Eric
    -Polk Audio
  • bigaudiofanatic
    edited July 2008
    My name is Matt and and I LOVE BI-AMPING!!!!! HAHA CRANK IT CRANK IT
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • zingo
    zingo Posts: 11,258
    edited July 2008
    I've used multiple outs on receivers before to bi-amp with results like yours. I'm glad it worked out for you as well!
