TV Stand Suggestions - need to fit CS400i
ahorvitz
I haven't posted in a while, but I've been lurking... occasionally.
I just upgraded from a RPTV to a DLP TV. I need a TV stand. While there's a lot of info out there, I'm having difficulty finding one with the right dimensions and/or adjustments.
My preference is for a 3 shelf (3rd = TV on top) something sliver / glass, black / glass, or just plain black, but I may be flexible there. The new TV is 61" and I've got a bit of gear that I'd like to get into this stand - center + 5 components. I'm game for a 60"+ lowboy, or something of the sort.
Requirement - my center channel is a CS400i (8.625" tall). I can't seem to find a stand that has enough room available on the upper shelf for the speaker.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Main Rig
Pioneer Elite SC-05, Rotel RMB-1075
RT800i, CS400i, RT35i, FXi50, Klipsch RSW-12
Pioneer Elite DV F-07, PS3, Wii
Monster HTS 3500 MKII
SC Analog 2, BJC Speaker Wire
Samsung HL61A650
2nd Rig
Pioneer Elite VSX-56txi, Pioneer Elite DV-47a
Cambridge Soundworks, MC150 (Center), MC100 x 4, Mirage LF-150
Office
Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i
Samsung HL61A650
2nd Rig
Office
Post edited by ahorvitz on
Have you thought about mounting the center on top of your TV? I used one like this (mine was black) and it worked really well.Mains.............Polk LSi15 (Cherry)
I hadn't thought of doing this, given the size of the speaker. But this says it'll hold 30 lbs. I'll look into it.
I'd still love to hear any suggestions on stands.Main Rig
Samsung HL61A650
2nd Rig
Office
Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i -
You could build one custom for yourself... If you want
I use one of these.
http://www.standsandmounts.com/index.asp?PageAction=VIEWPROD&ProdID=2846
Search around though. They're available in different widths and with rods for larger or smaller shelves.
The model I have allows the center rod under the TV to be installed a few inches back, allowing room for a center channel. I don't know if it's deep enough for yours though, but the height is right."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I built a custom shelf. Total cost was like 20 bucks for two brackets and I had an extra shelf lying around. I painted it black and cut out a notch in the back for the speaker wire to run through. It's was real easy to do! You can see pics in my signature
Email these guys, tell them the specifics and they will get back to you with options.
http://www.standsandmounts.comMy Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
I used the mount that McLoki linked to, to hold my CS400 and it worked great. I used it on a Sony Wega tube tv though. With the small depth of TV's these days I would make sure that this would work for you first. What TV model do you have?CS400 For Sale
WHen I used the mount, I used it with a Hitachi LCD (slim) rear projection. When I got my new plasma, it didn't work anymore and it was of to the basement system with the 36" tube TV it went...Mains.............Polk LSi15 (Cherry)
The TV is a Samsung HLS6187W. I have to believe the back is too steep to mount a shelf on; at least on to hold the CS400.
I may end up wall mounting the center above the tv or just sitting it up on its own pedestal, in front of the tv.
Thanks all for guidance.Main Rig
Samsung HL61A650
2nd Rig
Office
