TV Stand Suggestions - need to fit CS400i
ahorvitz
ahorvitz Posts: 235
I haven't posted in a while, but I've been lurking... occasionally.
I just upgraded from a RPTV to a DLP TV. I need a TV stand. While there's a lot of info out there, I'm having difficulty finding one with the right dimensions and/or adjustments.
My preference is for a 3 shelf (3rd = TV on top) something sliver / glass, black / glass, or just plain black, but I may be flexible there. The new TV is 61" and I've got a bit of gear that I'd like to get into this stand - center + 5 components. I'm game for a 60"+ lowboy, or something of the sort.
Requirement - my center channel is a CS400i (8.625" tall). I can't seem to find a stand that has enough room available on the upper shelf for the speaker.
Any suggestions?
Thanks.
Main Rig
Pioneer Elite SC-05, Rotel RMB-1075
RT800i, CS400i, RT35i, FXi50, Klipsch RSW-12
Pioneer Elite DV F-07, PS3, Wii
Monster HTS 3500 MKII
SC Analog 2, BJC Speaker Wire
Samsung HL61A650
2nd Rig
Pioneer Elite VSX-56txi, Pioneer Elite DV-47a
Cambridge Soundworks, MC150 (Center), MC100 x 4, Mirage LF-150
Office
Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i
Post edited by ahorvitz on
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    Have you thought about mounting the center on top of your TV? I used one like this (mine was black) and it worked really well.
  • ahorvitz
    ahorvitz Posts: 235
    edited July 2008
    McLoki wrote: »
    I hadn't thought of doing this, given the size of the speaker. But this says it'll hold 30 lbs. I'll look into it.
    I'd still love to hear any suggestions on stands.
    Main Rig
    Samsung HL61A650
    2nd Rig
    Office
  • ajsankot
    ajsankot Posts: 141
    edited July 2008
    You could build one custom for yourself... If you want
  • Face
    Face Posts: 14,340
    edited July 2008
    I use one of these.
    http://www.standsandmounts.com/index.asp?PageAction=VIEWPROD&ProdID=2846
    Search around though. They're available in different widths and with rods for larger or smaller shelves.
    The model I have allows the center rod under the TV to be installed a few inches back, allowing room for a center channel. I don't know if it's deep enough for yours though, but the height is right.
  • tecmo04
    tecmo04 Posts: 421
    edited July 2008
    I built a custom shelf. Total cost was like 20 bucks for two brackets and I had an extra shelf lying around. I painted it black and cut out a notch in the back for the speaker wire to run through. It's was real easy to do! You can see pics in my signature
  • hockeyboy
    hockeyboy Posts: 1,428
    edited July 2008
    Email these guys, tell them the specifics and they will get back to you with options.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • skevill
    skevill Posts: 38
    edited July 2008
    I used the mount that McLoki linked to, to hold my CS400 and it worked great. I used it on a Sony Wega tube tv though. With the small depth of TV's these days I would make sure that this would work for you first. What TV model do you have?
    CS400 For Sale
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    WHen I used the mount, I used it with a Hitachi LCD (slim) rear projection. When I got my new plasma, it didn't work anymore and it was of to the basement system with the 36" tube TV it went...
  • ahorvitz
    ahorvitz Posts: 235
    edited July 2008
    skevill wrote: »
    The TV is a Samsung HLS6187W. I have to believe the back is too steep to mount a shelf on; at least on to hold the CS400.
    I may end up wall mounting the center above the tv or just sitting it up on its own pedestal, in front of the tv.
    Thanks all for guidance.
    Main Rig
    Samsung HL61A650
    2nd Rig
    Office
