I got a DAC today.Big improvement too.
fbm211
fbm211 Posts: 1,488
edited July 2008 in Electronics
I finally got a GDA600 and all my CDs sound a-lot cleaner.Tighter bass,and much improved highs.It actually toned down the harshness of those sl2000s.:D...RDO198s will replace them next tax refund.I only have a standard rockfish coax for now but that will be replaced by a moon audio modded DH Labs D-75 next week.I have high expectations because of the rave reviews it has gotten.Im also planning on a monarchy audio DIP combo.Those SDAs and this forum have turned me into an upgrading ****..:o.I just cant stop. I want AQ Black mamba II interconnects,DH labs speaker cables,a theta transport, the mojo1 mod for the DAC.And the sonicap crossover rebuild.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Ern Dog
    Ern Dog Posts: 2,237
    edited July 2008
    Sounds like you got the upgrade bug. My advice is to give yourself everything you want! In the end you'll have a killer system and a wealth of experience.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2008
    Yeah.I got ot bad.My next purchase I think is going to be 20 ft of canare 4S11 speaker cable(I found a bulk dealer)and some silver plated eichmann bannanas.Ill get two single binding posts and use 9ft of the cable to make a custom IC cable.I just hope I can somehow rig the posts into the cups by removing the female IC inputs.
  • Face
    Face Posts: 14,340
    edited July 2008
    Drill a hole, install the binding post, swap wire from pin hole to new binding post. It's simple.
    F1nut Posts: 52,301
    edited July 2008
    I really hate to see all these SDA IC cable hack jobs. You do realize that you can still use the original pin hole, right?
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited July 2008
    What's wrong with replacing the SDA connector with a binding post? It's a much more solid connection, the original is very loose and sloppy. And if done right, it's not a hack job.
    F1nut Posts: 52,301
    edited July 2008
    WilliamM2 wrote: »
    Loose and sloppy? Hell, I have to get a firm grip and pull hard on mine to remove them. The fit couldn't be any tighter. Good luck if you ever need to use the AI-1.
  • WilliamM2
    edited July 2008
    I still have the original parts, the way I did it, it can be put back to original in 5 minutes.
    F1nut Posts: 52,301
    edited July 2008
    WilliamM2 wrote: »
    In that case, my hat is off to you for having that foresight.
