psw350
prisco88
I'm a new to the home audio seen so I may have many easy questions from now on. On the back off my sub- there's a port for unfiltered and two ports for filtered ( left & right) . right now i have it hooked up to unfiltered LFE . and whats LFE ? thax..
Post edited by prisco88 on
LFE stands for Low Frequency Effects. It's the ".1" in "5.1" soundtracks, a seperate channel just for bass.
The LFE input on the sub bypasses the variable low-pass crossover on the sub. Since the "Sub Out" on most (if not all) home theater receivers outputs a signal that is already filtered, you should use the "LFE In" on the sub and avoid filtering the signal twice. Does that make sense?
If your receiver dosen't have a "Sub Out", or if the crossover frequency of the "Sub Out" doesn't work well for you, you might be able to use the L&R Line In's on the sub (if you have Preamp Outs on your receiver). It all depends on the specifics of your setup. Doing so would likely require other settings and adjustments that may be beyond the scope of what you asked.
Hope that helps, and welcome to the forum!
Jason
And BTW, here's some more info about subwoofers and bass management.
http://www.polkaudio.com/home/faqad/advice.php?article=bassmanage
I'm finding this to be a very useful intro to various HT/HS topics:
http://www.polkaudio.com/home/library/downloads/hthandbook.pdf
good luckMain HT (family room): Polk Monitor 7 (1987-original owner) (L/R) / CSi40 (C) / RTi38 (SL/SR) / SVS 20-39PC (sub), Outlaw 975 pre/pro / Outlaw 7075 amp, Oppo BDP-93 Blu-ray, LG 42LM5800 teevee
2ch (family room): CRS+ (1987), Outlaw 1050 AVR, Denon DCM-420 CD
Kitchen satellite 2ch: Polk M3II, Topping TP-20 Tripath amp fed from 975 rec line out
Home office: Model 5 (1978-Danish Peerless), Lepai 2020A+ Tripath amp fed by laptop dock
Awaiting assignment: PSW202 (NIB) to be wired inline in home office rig; Monitor 5JR (1988), Model 4 (1983-US Peerless) -
jason, My receiver is a onkyo tx-ds595, i'll have to look in to it to see if it's filtered through the receiver . I'm a newbee to all this so i may ask some simple questions . thanks for the info.
welcome to the forum, prisco!
joe
prisco88-
I'm sure the sub out is a filtered signal. As I said, the best hookup depends on your specific equipment, but connecting your receiver's sub output to the LFE in on the sub is probably the most common hookup.
Jason
Simple questions are the only ones I have a chance at
