RTi12 have loose terminals
dcuz383
dcuz383 Posts: 9
Both of my RTi12's have loose speaker terminals on the back of the speaker. I was using my old reciever to Bi-amp with banana plugs. Now I have added a amp that requires the use of bare wire. When I installed the jumpers back on to the terminals I noticed that they are very loose and will not tighten. I removed the four screws on the plate and pulled them out of the cabinet only to find that there is no way to tighten that I can see. I put the wire through both terminals of each side and put it on a test run. The left speaker was not playing the top speakers. I wiggled the terminal in the back and it worked as long as held at an angle. Is there a way to tighten these terminals?
55" Sony LCD
Front RTi12's
Center CSi5
Surrounds TC80i's
Rears TC265i's
MicroPro 4000
PSW505
Yamaha RXV3800
QSC CX702
PS3
XBOX360
Harmony 1000
Monster Power Box
APC UPS
Post edited by dcuz383 on
  • dcuz383
    dcuz383 Posts: 9
    edited June 2008
    Help. Last night I was pushing them hard and the Yamaha AVR started to shut down and displayed "Check SP Wires". Could this be the loose terminals on my RTi12's?
    55" Sony LCD
    Front RTi12's
    Center CSi5
    Surrounds TC80i's
    Rears TC265i's
    MicroPro 4000
    PSW505
    Yamaha RXV3800
    QSC CX702
    PS3
    XBOX360
    Harmony 1000
    Monster Power Box
    APC UPS
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2008
    If you could upload some pictures I might be able to help; otherwise head over to the troubleshooting section.
  • crd2002
    crd2002 Posts: 174
    edited June 2008
    you can buy banana plugs at radio shack and use them and you should be fine
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
