Onkyo 805
dholmes
dholmes Posts: 1,136
edited July 2008 in Electronics
I have the Onkyo 805 & used the Audessey calibration & dont really like the sound,if I set the Onkyo volume to 0 & calibrate each spk to 75db with a test tone will it override the Audessey or is there a way to shut off the Audessey?thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
    billbillw Posts: 8,108
    edited June 2008
    You can alter the channel levels and still keep the Audyssey equalization. That is what I recommend.
    But before you make too many changes, let me ask: Did you do your Audyssey setup with a tripod and utilize all 8 positions? Did you have the microphone tip parallel with the floor? Did you use positions that are near ear height, but not too close to any walls, furniture, etc? They should be at least 18" from anything that could affect response (sofa, wall, table, etc).
    The trick to getting the most out of Audyssey it to feed it good data from as many points as possible. The points must be close to where you sit. I usually do 3 points to represent the positions on my sofa, then another 3 points about 2 feet behind the first 3, then another two points that fall just about 2 feet to the R/L of the sofa.
    You will almost always have to adjust the bass management manually. By default, Onkyo chooses to make all speakers that can pass below 50hz into "full range" speakers. Most of the time, you want to change this so that this bass is sent to the sub. Usually, you have to set the bass level manually too.
    Don't give up on Audyssey yet.
  • dholmes
    edited June 2008
    Thanks I didnt do all that Ill try it again
    edited June 2008
    dholmes wrote: »
    Just remember, you will probably still have to ''tweak" the bass management (crossover settings) and possibly the channel levels.
    But, after Audyssey does its EQ, you should find a much smoother response, cleaner imaging, tighter bass, etc.
  • dholmes
    edited June 2008
    Thanks again,will my 805 have the same pop as my 9.8 with dts hd ma?
  • jon s
    jon s Posts: 905
    edited June 2008
    depends... look at the firmware for the DSPs... don't remember the procedure tho... go oto AVSForums, look under the Blu-Ray Players subforum... there is a whole section for the DTS HD Master issue...
    edited June 2008
    dholmes wrote: »
    If it does, I can send you the DSP update that fixes the problem.
  • dholmes
    edited June 2008
    Is there someting wrong with the 805 also,I havnt hooked up the hdmi yet will it have the same dts pop??thanks
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited June 2008
    dholmes wrote: »
    Yep, It will more than likely happen at the same time stamp on what ever movie you where watching with your Integra.
    cheddar wrote: »
    Some DTS-HD MA tracks were not encoded properly and a few disks will have what decodes to a loud gunshot bang on them when played back on various receiver/pre-amps. This has the potential to cause damage to speakers as it's much louder than the original listening level. The 805 and 9.8 have an update to their DSP firmware that disables the faulty encoded signal from getting past them. Supposedly, new movies will be encoded correctly without the 'bomb'. But it's better to be safe since the DSP update is actually easier to do with the Onkyos than updating the main firmware.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • xandra
    xandra Posts: 291
    edited June 2008
    d... Your 805 may already contain the needed dsp&firmware update. Go the Official Onkyo 805 thread on AVSforums for instructs on how to find out...
    I've heard from quite a few folks that their recently purchased 805's were already updated.
    YMMV
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • dholmes
    edited July 2008
    Thanks again,theres so many post on this at avs whats the way to check to see what version I have to see if I have the POP?
    edited July 2008
    dholmes wrote: »
    Read the attached PDF file. Its the instructions that came with the DSP upgrade and it tells you what versions you will have after the upgrade.
    Do what it says in step 3 to see if you already have those versions. If you do, then you are fine.
    The instructions are somewhat vague. The button presses all have to be on the receiver (not the remote). After you press the standby/display combo, you have three seconds to make a selection. This is where you press the Tone > button (which is the 3rd from the left on the bottom row) to cycle through the firmware editions. There is a Main, DSP1, DSP2, etc.
    It will stay active as long as you press that > button at least every 2-3 seconds.
