Suggestion for 2 channel stereo racks
Norm Apter
I'd like to know if any folks have suggestions for sturdy 2 channel stereo racks (brands and model suggestions both o.k.). My two top concerns are durability and an ability to allow my system to "breathe." A tertiary consideration would be style (with the principle of simplicity highly valued).
When all is said and done, I'll be looking to support 4 components: the Halo line of amp, pre and tuner plus a black Marantz CD player. I am thinking that black and metallic would be nice as this would help "neutralize" the contrast between the Halo components' silver color scheme and the black CD player. It seems that many Home Theater racks are horizontally orientated and close to the ground. I'd like something vertically oriented, though, so that I don't need to bend down every time I want to change a CD.
Each of the Halo components are of the following dimensions: 17-1/4" w x 4-1/8" h x 13-1/4" d. The CD player has the same width, but is shorter and has less physical depth.
Thanks for any leads.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
http://www.vtimanufacturing.com/Audio%20racks%20&%20AV%20stands.htm
IMO, their 4 leg systems offer more flexibility."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
TNT Flexy. Not for everyone, but easy to make, low cost, and you can tailor it to your needs. I have made 4 now.
Face, have you bought stuff from them before? I just visited the website and found some nice looking racks, but couldn't find any info on pricing or sales. Do you know if they take on-line orders or if their merchandise can only be bought at retail shores?2 Ch.
HT
Denon 2808ci AVR
Signal Cable Analog II Interconnects -
James, I'm also possibly interested in this route, especially in the light of the flexibility that comes with building one's own rack. Can you tell me more about where I could find such materials? And I don't suppose you have a pic of one of your racks available?2 Ch.
HT
Denon 2808ci AVR
Here's a example.Norm Apter wrote: »James, I'm also possibly interested in this route, especially in the light of the flexibility that comes with building one's own rack. Can you tell me more about where I could find such materials? And I don't suppose you have a pic of one of your racks available?
http://www.jetcom.org/~jsb/flexirack.php
I believe the supplies are available at most Home Depots or Lowes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Norm, click my bedroom ht link in my sig 3rd pic is a decent one. That rack cost me <$100 in materials and took about 3 hours. It fits all my needs, isn't to deep, and allowed me to segregate all my components and is the exact width of my TV so no wasted space. When I watch a movie I put the covers on and I am gtg...no distracting LEDs.
I have another pic of a rack I made in my previous rigs section. It was more then capable of holding all my gear, even my 140lb cinenova on top. Another still can be found in my current system, pic #25, it is my storage flexy for all my media (pic is bad, I gotta retake that one).
As for materials I just use cheap MDF from home depot, flat black paint, and threaded rods. Your local lowes/HD should have everything you needs, and they can even cut the wood. The only tools required are pliers and a drill.
You can make yours look much nicer, I know some that will use a cherry or ebony veneer, others still have used exotic materials like marble or acrylic. You can also paint the rods or cover them with something, but I like the look. -
Salamander triple twenty---but it's pricey at approx $1400. The wood is mucho thick and gorgeous; the stand extremely sturdy. I have one in Cherry, it's a work of art.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
For simplicity and durability we chose the Omni G-304. It makes it easy to
spin a component around for access to wiring and it's built for about 50# per shelf. It also shows off your equipment while the rack[stand] almost
disappears except for the front. Mine is black and came with clear glass but the newer models have black glass that I prefer. This post should have a couple of pictures attached.
You did say simplicity, durability and vertical. Right?
http://www.omnimount.com/consumer/product.aspx?ProductId=95504efd-cbef-4d92-a4d3-2ee59c26ef13SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
Completely forgot, if you aren't into DIY Salamander Archetype is really customizable. -
elfa shelf systems from the container store - comes in 2 types of shelves, wire and solid
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
Thanks for the suggestions everyone. Lots of good ideas, here. Looks like I'll need a little time to consider budget and that sort of thing. Off the top of my head, I do like that Omnimount G304 that Neskahi suggested as its directs more attention to the components than the rack itself, and these Parasound Halos are practically screaming for attention, "Hey, check me out"....ha, ha2 Ch.
HT
Denon 2808ci AVR
I purchased the BL404 from VTI and really like it. It is modular, looks good (you can select the tube, shelf and cap colours) and you can fill the tubes. I filled the tubes with lead shot and it is solid as a rock. Looks good too.Michael
NORTH of 60° -
Puritan PSM156 -
Racks and stands sometimes has very poor communication."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Lovan Classic. Can't remember what site I got it from, but got it for $199 shipped (free shipping) and they allowed paypal payment. Great stand, great price, great company.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Studio Tech has great customer service and offers online ordering and free shipping. The are also available at Racks and stands (mentioned above)
http://www.studiotech.com/products/component_cabinets/index.html
http://www.studiotech.com/products/component_racks/index.html
I have the HF-3 with a an extra shelf for the HT. I'm saving up for the U-48 for 2 Ch. I saw it in a local audio store and was impressed by the construction, versatility and looks. Also, no complaints from me about the HF-3. Glad I bought it.Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
I bought a stand of their 3-legged stuff. Its very nice. -
I own this one- http://www.racksandstands.com/Bello-AT-484-BB0018.html -and am quite fond of it. One potential issue is the 50 lb limit per shelf but if that is not an issue then you should consider it. Four adjustable shelves with the ability to add more shelves if needed. I really like the way the components are staggered when you fill the rack.The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. -
4 post flexi rack here. I did the version with 5/8 rod and covered the
threaded portions with painted lengths of pvc pipe. I used a jig
on a miter box to cut the pvc to equal lengths, making the rack
setup easier. It isn't easy to change shelf spacing, but it works
for me."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
