Suggestion for 2 channel stereo racks
Norm Apter
Norm Apter Posts: 1,036
edited June 2008 in 2 Channel Audio
I'd like to know if any folks have suggestions for sturdy 2 channel stereo racks (brands and model suggestions both o.k.). My two top concerns are durability and an ability to allow my system to "breathe." A tertiary consideration would be style (with the principle of simplicity highly valued).
When all is said and done, I'll be looking to support 4 components: the Halo line of amp, pre and tuner plus a black Marantz CD player. I am thinking that black and metallic would be nice as this would help "neutralize" the contrast between the Halo components' silver color scheme and the black CD player. It seems that many Home Theater racks are horizontally orientated and close to the ground. I'd like something vertically oriented, though, so that I don't need to bend down every time I want to change a CD.
Each of the Halo components are of the following dimensions: 17-1/4" w x 4-1/8" h x 13-1/4" d. The CD player has the same width, but is shorter and has less physical depth.
Thanks for any leads.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • Face
    Face Posts: 14,340
    edited June 2008
    http://www.vtimanufacturing.com/Audio%20racks%20&%20AV%20stands.htm
    IMO, their 4 leg systems offer more flexibility.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    TNT Flexy. Not for everyone, but easy to make, low cost, and you can tailor it to your needs. I have made 4 now.
  • Norm Apter
    edited June 2008
    Face wrote: »
    Face, have you bought stuff from them before? I just visited the website and found some nice looking racks, but couldn't find any info on pricing or sales. Do you know if they take on-line orders or if their merchandise can only be bought at retail shores?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Norm Apter
    edited June 2008
    Gaara wrote: »
    James, I'm also possibly interested in this route, especially in the light of the flexibility that comes with building one's own rack. Can you tell me more about where I could find such materials? And I don't suppose you have a pic of one of your racks available?
    2 Ch.
    HT
    Denon 2808ci AVR
  • Face
    Face Posts: 14,340
    edited June 2008
    http://www.standsandmounts.com/
    I've dealt with them a few times, all positive experiences.
  • Face
    Face Posts: 14,340
    edited June 2008
    Norm Apter wrote: »
    Here's a example.
    http://www.jetcom.org/~jsb/flexirack.php
    I believe the supplies are available at most Home Depots or Lowes.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    Norm, click my bedroom ht link in my sig 3rd pic is a decent one. That rack cost me <$100 in materials and took about 3 hours. It fits all my needs, isn't to deep, and allowed me to segregate all my components and is the exact width of my TV so no wasted space. When I watch a movie I put the covers on and I am gtg...no distracting LEDs.
    I have another pic of a rack I made in my previous rigs section. It was more then capable of holding all my gear, even my 140lb cinenova on top. Another still can be found in my current system, pic #25, it is my storage flexy for all my media (pic is bad, I gotta retake that one).
    As for materials I just use cheap MDF from home depot, flat black paint, and threaded rods. Your local lowes/HD should have everything you needs, and they can even cut the wood. The only tools required are pliers and a drill.
    You can make yours look much nicer, I know some that will use a cherry or ebony veneer, others still have used exotic materials like marble or acrylic. You can also paint the rods or cover them with something, but I like the look.
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2008
    Salamander triple twenty---but it's pricey at approx $1400. The wood is mucho thick and gorgeous; the stand extremely sturdy. I have one in Cherry, it's a work of art.
  • Neskahi
    Neskahi Posts: 297
    edited June 2008
    For simplicity and durability we chose the Omni G-304. It makes it easy to
    spin a component around for access to wiring and it's built for about 50# per shelf. It also shows off your equipment while the rack[stand] almost
    disappears except for the front. Mine is black and came with clear glass but the newer models have black glass that I prefer. This post should have a couple of pictures attached.
    You did say simplicity, durability and vertical. Right?
    http://www.omnimount.com/consumer/product.aspx?ProductId=95504efd-cbef-4d92-a4d3-2ee59c26ef13
    SDA 2.3/RDO's... xovers by Ben
    SDA 2.3TL/Stock..
    SDA 1C/Solens/RDO's [gave to my Uncle]
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    M91 x 2 Pioneers/C91 Pre
    Yaqin MC10l
    DCD-1520/1560/2560 Denon
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
    steveinaz wrote: »
    Completely forgot, if you aren't into DIY Salamander Archetype is really customizable.
  • SlowcarIX
    SlowcarIX Posts: 887
    edited June 2008
    elfa shelf systems from the container store - comes in 2 types of shelves, wire and solid
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • Norm Apter
    edited June 2008
    Thanks for the suggestions everyone. Lots of good ideas, here. Looks like I'll need a little time to consider budget and that sort of thing. Off the top of my head, I do like that Omnimount G304 that Neskahi suggested as its directs more attention to the components than the rack itself, and these Parasound Halos are practically screaming for attention, "Hey, check me out"....ha, ha
    2 Ch.
    HT
    Denon 2808ci AVR
  • janmike
    janmike Posts: 6,146
    edited June 2008
    I purchased the BL404 from VTI and really like it. It is modular, looks good (you can select the tube, shelf and cap colours) and you can fill the tubes. I filled the tubes with lead shot and it is solid as a rock. Looks good too.
    Michael ;)
    NORTH of 60°
  • marvda1
    marvda1 Posts: 4,951
    edited June 2008
    Puritan PSM156
  • Face
    Face Posts: 14,340
    edited June 2008
    Racks and stands sometimes has very poor communication.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2008
    Lovan Classic. Can't remember what site I got it from, but got it for $199 shipped (free shipping) and they allowed paypal payment. Great stand, great price, great company.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Gadabout
    Gadabout Posts: 1,072
    edited June 2008
    Studio Tech has great customer service and offers online ordering and free shipping. The are also available at Racks and stands (mentioned above)
    http://www.studiotech.com/products/component_cabinets/index.html
    http://www.studiotech.com/products/component_racks/index.html
    I have the HF-3 with a an extra shelf for the HT. I'm saving up for the U-48 for 2 Ch. I saw it in a local audio store and was impressed by the construction, versatility and looks. Also, no complaints from me about the HF-3. Glad I bought it.
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2008
    Face wrote: »
    I bought a stand of their 3-legged stuff. Its very nice.
  • unbridled_id
    unbridled_id Posts: 179
    edited June 2008
    I own this one- http://www.racksandstands.com/Bello-AT-484-BB0018.html -and am quite fond of it. One potential issue is the 50 lb limit per shelf but if that is not an issue then you should consider it. Four adjustable shelves with the ability to add more shelves if needed. I really like the way the components are staggered when you fill the rack.
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
  • sucks2beme
    sucks2beme Posts: 5,684
    edited June 2008
    4 post flexi rack here. I did the version with 5/8 rod and covered the
    threaded portions with painted lengths of pvc pipe. I used a jig
    on a miter box to cut the pvc to equal lengths, making the rack
    setup easier. It isn't easy to change shelf spacing, but it works
    for me.
