Breaker Panel load calculations?
obieone
I've got a 200 amp service in my house. I'm trying to find out how much, if any, headroom I've got in my panel for future additions.
Here's the breakdown:
1-2 pole 40 amp
3-2 pole 30 amp
1-2 pole 20 amp
7-1 pole 20 amp
6-1 pole 15 amp
I'm looking at building a 2 car garage and running wire for a 60 amp service, but installng 30 amp for now. Also, may be building an addition with 1-20 amp, and 1-15 amp.
If I've got to jump to a 400 amp panel before doing anything, I'd like to find out now.
1-2 pole 40 amp
3-2 pole 30 amp
1-2 pole 20 amp
7-1 pole 20 amp
6-1 pole 15 amp
Do you plan on turning everything on at once?
LOL, no. I wasn't sure if there's a rule for calculating a safe load. I have 7 more 1 pole openings left but, I'm trying to avoid any issues in the future.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
I'm no electrician but if what's in my house you're fine.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
You should be fine, although you should check with your local electrical codes.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
You're fine. The only time you would need 400 amp service would be for commercial applications, where you might actually need more than 200 amps. You won't need it... -
I've got an electrician coming out tomorrow, he's replacing my 100amp panel with a 200amp. My panel is full and I need another spot for a third breaker for my theater. I have all the gear on one breaker and the lighting on another, I want to separate the video from the audio so they each can have their own breaker.If...
Ron loves a film = don't even rent.
