Breaker Panel load calculations?
obieone
edited June 2008 in DIY, Mods & Tweaks
I've got a 200 amp service in my house. I'm trying to find out how much, if any, headroom I've got in my panel for future additions.
Here's the breakdown:
1-2 pole 40 amp
3-2 pole 30 amp
1-2 pole 20 amp
7-1 pole 20 amp
6-1 pole 15 amp
I'm looking at building a 2 car garage and running wire for a 60 amp service, but installng 30 amp for now. Also, may be building an addition with 1-20 amp, and 1-15 amp.
If I've got to jump to a 400 amp panel before doing anything, I'd like to find out now.
  • amulford
    edited June 2008
    Do you plan on turning everything on at once?
  • obieone
    edited June 2008
    LOL, no. I wasn't sure if there's a rule for calculating a safe load. I have 7 more 1 pole openings left but, I'm trying to avoid any issues in the future.
  • disneyjoe7
    edited June 2008
    I'm no electrician but if what's in my house you're fine.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Serendipity
    edited June 2008
    You should be fine, although you should check with your local electrical codes.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • amulford
    edited June 2008
    obieone wrote: »
    You're fine. The only time you would need 400 amp service would be for commercial applications, where you might actually need more than 200 amps. You won't need it...
  • Ron-P
    edited June 2008
    I've got an electrician coming out tomorrow, he's replacing my 100amp panel with a 200amp. My panel is full and I need another spot for a third breaker for my theater. I have all the gear on one breaker and the lighting on another, I want to separate the video from the audio so they each can have their own breaker.
    If...
    Ron loves a film = don't even rent.
