FXi30
ednem
ednem Posts: 4
What is the best option to wallmounted FXi30?
Post edited by ednem on
  • ChrisDurano
    ChrisDurano Posts: 372
    edited April 2003
    It really depends on where your seating is. If you plan on putting the surrounds on the sides, you should switch them to "dipole" and make sure your seating is in the "null" area. If you plan on putting the speaker behind you on the rear wall, switch them to bipole.
    Bipole/Dipole
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • ednem
    ednem Posts: 4
    edited April 2003
