FXi30
ednem
What is the best option to wallmounted FXi30?
Post edited by ednem on
It really depends on where your seating is. If you plan on putting the surrounds on the sides, you should switch them to "dipole" and make sure your seating is in the "null" area. If you plan on putting the speaker behind you on the rear wall, switch them to bipole.
Bipole/DipoleHome Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Car speakers polkaudio EX 369, DB 650 -
thanks
