SL2000 tweeter frequency response plots anybody?
daifanshi
I'm looking for an anaechoic frequency response plot of the SL2000 tweeter. One that clearly shows the +6db 10-13khz resonance that most believe is the cause of that tweeter's "harshness".
Or if there is a magazine review of the 1980's vintage Polk speakers that show that response resonance in good detail that would be helpful too.
Unfortunately I don't a SL2000 tweeter of my own...
Any other details such as the electrical and mechanical parameters will be useful too (if they exist in the public domain).
The purpose is to build an active filter to null the resonance at line level.
Thanks!
Thanks!
Post edited by daifanshi on
I was tolk by a Polk employee that the company considers the electrical and mechanical parameters, as well as the response characteristics of the SL2000 tweeter to be proprietary information. Oddly enough, they did publish the response curve for the SL3000 tweeter in a technical paper dated September 1989. The technical paper is titled "SL 3000 Dome Tweeter".
High Fidelity magazine published a room response chart in their review of the SDA SRS 2 (November 1986, page 37).
Active equalization of the type you are proposing will have some other undesirable effects which may be worse than the SL2000 resonance.
My posts in this thread (beginning at post #10) may provide some useful insight: SDA-SRS Crossover PointsProud and loyal citizen of the Digital Domain and Solid State Country! -
Buy the new replacement tweeter....problem solved.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
that's to easy of a solution.. and it makes sense
PolkFest 2012, who's going>?
DarqueKnight wrote: »I was tolk by a Polk employee that the company considers the electrical and mechanical parameters, as well as the response characteristics of the SL2000 tweeter to be proprietary information. Oddly enough, they did publish the response curve for the SL3000 tweeter in a technical paper dated September 1989. The technical paper is titled "SL 3000 Dome Tweeter".
Can you tell me specifically what "undesirable effects" you are referring to? Just curious... -
I've heard this is the standard solution to the SL2000 problem. Unfortunately at 50 bucks a tweeter, this is expensive for a lot of people. Especially true if you have an one of the the SDA speaker systems with the SL2000.
An active filter is an elegant solution that takes a few IC's and a power supply. For those with technical ability and more time than money, it will certainly be less than the cost of one tweeter. -
An active filter is an elegant solution that takes a few IC's and a power supply. For those with technical ability and more time than money, it will certainly be less than the cost of one tweeter.Can you tell me specifically what "undesirable effects" you are referring to? Just curious...
How about sound quality? You are proposing to improve the sound of the SL2000, yet you want to run the signal through a few cheap IC's.Proud and loyal citizen of the Digital Domain and Solid State Country! -
DarqueKnight wrote: »How about sound quality? You are proposing to improve the sound of the SL2000, yet you want to run the signal through a few cheap IC's.
This is a curious statement and not very specific.
I don't know where the "cheap IC" assumption came from. But very high performance audio op amps such as TI OPA2604's are available for around 4 bucks a pop at small quantity. And nothing is being touched in the speaker system, we're just adding a few good op-amps to the preamp signal chain.
The only thing I believe that can possibly cause problems is differential group delay if the notch filter is very deep. But then this potential "problem" is only localized to the frequency resonance anyways and that 6dB peak is gonna be much worst than a few hundred micro seconds of localized group delay.
I GUARANTEE that OPA2604's are better than any of the dozen or so op-amps and transistors that were in the studio's mixing console or are in most people's CD players, preamps, or power amps today. There's lots of audio electronics from the 80's, 90's, and now that have old NE5532 and TL072 op-amps in them. :eek: -
Its not just the 12k bump. The SL2000 deteriorates with age more like milk than whiskey. They are not just harsh at the bump, but the breakup/harshness is heard in lower frequency ranges. Look at the schematic, and at least replace the two tweeters that run near full range. Remember give them time to burn in. They are fairly harsh in the beginning.
Ben -
This reminds me of the smell of hot tar.:eek:I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
MillerLiteScott wrote: »This reminds me of the smell of hot tar.:eek:
WAAAAAAAAAAAAAAAAAAAAAAAAAAPolitical Correctness'.........defined
President of Club Polk -
Didn't CandyLiquor's thread(ss) about using caps end up with someone posting RTA analysis of the Sl2000 with and without mod?
This was maybe 2-3 months ago. I can't remember the members name who posted the info, unfortunately. -
You claim to own a pair of TL's, but you're so interested in the SL2000's... :rolleyes:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks. I didn't want to be the one to say it.;)Proud and loyal citizen of the Digital Domain and Solid State Country! -
An active notch filter is such a simple circuit for those who have used them and I enjoy working with active filters in general.
I'm sure there are many who can't afford the cost of replacing their tweeters to fix response problems with the SL2000. If I'm guilty of anything, it's offering my expertise for free. I'm sorry if that offends anybody.
Interesting comment considering that you don't have any experience with SDA's.Political Correctness'.........defined
I own a pair. Is there something more that qualifies as "experience"? I also removed the crossover on one to examine it. I fixed a cold solder joint that looked like it was close to intermittent. -
Thanks for proving my point.I recently bought a pair of 2.3TL's locally from craigslist for a very reasonable price.Political Correctness'.........defined
Thanks!
It's been mentioned and perhaps plotted in a few "stereo" rags of the day when some of the Polk speakers were tested when new. Check out your local library or an on-line resource. That's likely as close as you will come to any kind of accurate, controlled meaningful measurement. The info from Polk is proprietary and they don't share those types of things publicly.
Also, impress us....................use the search function. Everything you have talked about in all your threads concerning the tweeter and ways of improving the SDA have been discussed many times on this board. Your questions aren't unique and answers to everything you've asked has been answered multiple times. Make the effort and do the research. If you really want to know then spending a little time reading won't hurt you.
What do you know. No CL here either.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Nah....he's on Craigslist looking for cars to post in the Vintage Automobile thread he started.
Another funny thing... All 31 posts are in two threads focusing on the salvation of the SL2000 tweeter which he claims to have none:rolleyes:
Ben -
You wouldn't say "unfortunately" if you did have one ;-)Unfortunately I don't a SL2000 tweeter of my own... -
Carl is "daifanshi" your new alias?
The knowledge of certain technical details is a dead give away that they are not the same poster.hearingimpared wrote: »Carl is "daifanshi" your new alias?Testing
Testing
Testing -
At some point I saw response curves of the sda crossovers and it looked to me that the crossovers produced the peak rather than the drivers. I will say the replacement tweeters sound better, just not sure it is because of this peak. The capacitor modification may have some merit but it has not been proven.
