SL2000 tweeter frequency response plots anybody?
daifanshi
daifanshi Posts: 46
edited June 2008 in Vintage Speakers
I'm looking for an anaechoic frequency response plot of the SL2000 tweeter. One that clearly shows the +6db 10-13khz resonance that most believe is the cause of that tweeter's "harshness".
Or if there is a magazine review of the 1980's vintage Polk speakers that show that response resonance in good detail that would be helpful too.
Unfortunately I don't a SL2000 tweeter of my own...
Any other details such as the electrical and mechanical parameters will be useful too (if they exist in the public domain).
The purpose is to build an active filter to null the resonance at line level.
Thanks!
Post edited by daifanshi on
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2008
    I was tolk by a Polk employee that the company considers the electrical and mechanical parameters, as well as the response characteristics of the SL2000 tweeter to be proprietary information. Oddly enough, they did publish the response curve for the SL3000 tweeter in a technical paper dated September 1989. The technical paper is titled "SL 3000 Dome Tweeter".
    High Fidelity magazine published a room response chart in their review of the SDA SRS 2 (November 1986, page 37).
    Active equalization of the type you are proposing will have some other undesirable effects which may be worse than the SL2000 resonance.
    My posts in this thread (beginning at post #10) may provide some useful insight: SDA-SRS Crossover Points
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2008
    Buy the new replacement tweeter....problem solved.
  • danger boy
    danger boy Posts: 15,722
    edited June 2008
    dorokusai wrote: »
    that's to easy of a solution.. and it makes sense :p
    PolkFest 2012, who's going>?
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    Can you tell me specifically what "undesirable effects" you are referring to? Just curious...
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    dorokusai wrote: »
    I've heard this is the standard solution to the SL2000 problem. Unfortunately at 50 bucks a tweeter, this is expensive for a lot of people. Especially true if you have an one of the the SDA speaker systems with the SL2000.
    An active filter is an elegant solution that takes a few IC's and a power supply. For those with technical ability and more time than money, it will certainly be less than the cost of one tweeter.
  • DarqueKnight
    edited June 2008
    daifanshi wrote: »
    daifanshi wrote: »
    How about sound quality? You are proposing to improve the sound of the SL2000, yet you want to run the signal through a few cheap IC's.
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    This is a curious statement and not very specific. :confused: I don't know where the "cheap IC" assumption came from. But very high performance audio op amps such as TI OPA2604's are available for around 4 bucks a pop at small quantity. And nothing is being touched in the speaker system, we're just adding a few good op-amps to the preamp signal chain.
    The only thing I believe that can possibly cause problems is differential group delay if the notch filter is very deep. But then this potential "problem" is only localized to the frequency resonance anyways and that 6dB peak is gonna be much worst than a few hundred micro seconds of localized group delay.
    I GUARANTEE that OPA2604's are better than any of the dozen or so op-amps and transistors that were in the studio's mixing console or are in most people's CD players, preamps, or power amps today. There's lots of audio electronics from the 80's, 90's, and now that have old NE5532 and TL072 op-amps in them. :eek:
  • ben62670
    ben62670 Posts: 15,969
    edited June 2008
    Its not just the 12k bump. The SL2000 deteriorates with age more like milk than whiskey. They are not just harsh at the bump, but the breakup/harshness is heard in lower frequency ranges. Look at the schematic, and at least replace the two tweeters that run near full range. Remember give them time to burn in. They are fairly harsh in the beginning.
    Ben
    Ben
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2008
    This reminds me of the smell of hot tar.:eek:
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    F1nut Posts: 51,944
    edited June 2008
    WAAAAAAAAAAAAAAAAAAAAAAAAAA
  • ShinAce
    ShinAce Posts: 1,194
    edited June 2008
    Didn't CandyLiquor's thread(ss) about using caps end up with someone posting RTA analysis of the Sl2000 with and without mod?
    This was maybe 2-3 months ago. I can't remember the members name who posted the info, unfortunately.
  • Face
    Face Posts: 14,340
    edited June 2008
    You claim to own a pair of TL's, but you're so interested in the SL2000's... :rolleyes:
  • DarqueKnight
    edited June 2008
    Thanks. I didn't want to be the one to say it.;)
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    Face wrote: »
    An active notch filter is such a simple circuit for those who have used them and I enjoy working with active filters in general.
    I'm sure there are many who can't afford the cost of replacing their tweeters to fix response problems with the SL2000. If I'm guilty of anything, it's offering my expertise for free. I'm sorry if that offends anybody. :(
    F1nut Posts: 51,944
    edited June 2008
    Interesting comment considering that you don't have any experience with SDA's.
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    :confused:
    I own a pair. Is there something more that qualifies as "experience"? I also removed the crossover on one to examine it. I fixed a cold solder joint that looked like it was close to intermittent.
    F1nut Posts: 51,944
    edited June 2008
    daifanshi wrote: »
    :confused:
    Thanks for proving my point.
    daifanshi wrote: »
    I recently bought a pair of 2.3TL's locally from craigslist for a very reasonable price.
  • daifanshi
    daifanshi Posts: 46
    edited June 2008
    You're welcome. :cool:
    heiney9 Posts: 25,492
    edited June 2008
    daifanshi wrote: »
    Thanks!
    It's been mentioned and perhaps plotted in a few "stereo" rags of the day when some of the Polk speakers were tested when new. Check out your local library or an on-line resource. That's likely as close as you will come to any kind of accurate, controlled meaningful measurement. The info from Polk is proprietary and they don't share those types of things publicly.
    edited June 2008
    Also, impress us....................use the search function. Everything you have talked about in all your threads concerning the tweeter and ways of improving the SDA have been discussed many times on this board. Your questions aren't unique and answers to everything you've asked has been answered multiple times. Make the effort and do the research. If you really want to know then spending a little time reading won't hurt you.
  • ben62670
    edited June 2008
    What do you know. No CL here either.
    Ben
    edited June 2008
    ben62670 wrote: »
    Nah....he's on Craigslist looking for cars to post in the Vintage Automobile thread he started. :D
  • ben62670
    edited June 2008
    Another funny thing... All 31 posts are in two threads focusing on the salvation of the SL2000 tweeter which he claims to have none:rolleyes:
    Ben
    Ben
    mhardy6647 Posts: 35,200
    edited June 2008
    You wouldn't say "unfortunately" if you did have one ;-)
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2008
    Carl is "daifanshi" your new alias?
  • Systems
    Systems Posts: 14,872
    edited June 2008
    The knowledge of certain technical details is a dead give away that they are not the same poster.
    Testing
    Testing
    Testing
  • madmax
    madmax Posts: 12,434
    edited June 2008
    At some point I saw response curves of the sda crossovers and it looked to me that the crossovers produced the peak rather than the drivers. I will say the replacement tweeters sound better, just not sure it is because of this peak. The capacitor modification may have some merit but it has not been proven.
    madmax
    Vinyl, the final frontier...
